Cypress技术william hill官网
沈铿僖
7年用户 180经验值
Windows 10不接受FX3的驱动程序
我正试图通过USB与FPGA开发板通信。该设备在Windows 10设备管理器中显示为FX3,带有感叹号。
我已经尝试去Windows 10设备管理器,找到FX3显示在“其他设备”的感叹号。右键单击并选择“更新驱动程序”,然后“浏览我的计算机驱动软件”,将其指向具有CysB3.IF和CysB3.3系统的文件夹,然后单击“下一步”。然后我得到下面的信息:“Windows无法安装你的FX3”“Windows找不到你的设备驱动程序……”
我的Windows版本:Windows 10的64位版本1803,OS版本17134.137
我安装了柏fx3sdksetup_1.3.4指出,Windows 10的64位驱动程序文件夹中找到cyu***.inf和cyu***3.sys
一切正常的Windows 7下,但我的电脑死机了,我回不去。
我很感激我能得到的任何帮助。
以上来自于百度翻译
     以下为原文
  I am trying to communicate to an enclustra FPGA development board through USB. The device shows up in the Windows 10 device manager as FX3 with an exclamation mark.
I have tried to go to windows 10 device manager, find the FX3 that shows under "other devices" with an exclamation mark. Right click and select "update driver" then "browse my computer for driver software" point it to the folder that has the cyu***3.inf as well as cyu***3.sys in it and click "next". Then I get the following message: "Windows was unable to install your FX3" "Windows could not find drivers for your device..."
My windows version is: Windows 10 64 bit, Version 1803, OS Build 17134.137
I installed Cypress FX3SDKSetup_1.3.4 and pointed to the windows 10 64 bit driver folder to find cyu***.inf and cyu***3.sys
Everything was working fine under windows 7 but my PC crashed and I can not go back to that.
I appreciate any help I can get.
回帖(1)
沈铿僖
2018-8-31 15:45:07
我已经得到了塞浦路斯的支持,这个问题得到解决。附上的文档显示了如何使驱动程序在Windows 10中工作。
感谢来自柏树支持团队的斯里达尔,为您的快速支持和解决我的问题。
Win 10 DOXX中的驱动程序绑定
1.9兆字节
以上来自于百度翻译
     以下为原文
  I have gotten support from Cypress on this and the issue is resolved. The attached document shows how to make the driver work in Windows 10.
Thank you Sridhar from the Cypress support team for your fast support and resolving my issue.
