实际上,您不需要在两个不同的文件夹中安装整个MPLABX,以实现所需的分离,并为MHC(和其他插件)运行不同版本。只需指定第二个UserDir,就可以配置第二个MPLABX实例,就像这里基本上描述的那样,您只需创建对MPLABX IDE的一个快捷方式,可添加一个-Urdidir & lt;Posirl和Gr.PrimeRI运行Linux,所以我的主要MPLAB快捷方式是/opt/Microchip /MPLABX/V3.40/MPLABUIDIDE/BIN/MPLABBIDED,而二级实例,具有不同版本的插件,我需要检查或测试的是/opt/Microchip /MPLABX/V3.40/MP。LabyID/BIN/MPLABABIDE——USEDIR/HOME/HOL/法比奥/MPLABIDE2同样适用于Windows /McCalassFabIO
以上来自于百度翻译
以下为原文
Hi.
Actually you don't need to install the whole MplabX in two different folders to achieve the needed separation and run different versions for MHC (and other plugins).
Simply configure a second MplabX instance by specifying a second UserDir, like described
here
Basically, you simply have to create a shortcut to the MplabX IDE executable adding a --userdir
parameter
I run Linux so my main Mplab shortcut is
/opt/microchip/mplabx/v3.40/mplab_ide/bin/mplab_ide
while the secondary instance, with different versions for plugins that I need to check or test is
/opt/microchip/mplabx/v3.40/mplab_ide/bin/mplab_ide --userdir /home/fabio/.mplab_ide2
The same applies to Windows/Mac
Cheers
Fabio
以上来自于百度翻译
以下为原文
Hi.
here
parameter
Cheers
Fabio
