FMC引脚支持高速。
是的套接字连接器是必需的,但FMC插座连接器假设在daugher板上的tomount。
要了解有关Xilinx FMC板的更多详细信息,请访问以下Xilinx网站http://www.xilinx.com/products/boards_kits/fmc.htm。
_______________________________________________如果有助于解决您的查询,请将此帖子标记为“接受为解决方案”。
因此,它将有助于其他william hill官网
用户直接参考答案。如果您认为该信息有用且面向答复,请给予此帖子称赞。
以上来自于谷歌翻译
以下为原文
FMC pins support high-speed.
Yes socket connector required, But that FMC socket conector suppose to mount on daugher board.
To know more details about Xilinx FMC boards refer the following Xilinx website http://www.xilinx.com/products/boards_kits/fmc.htm.
________________________________________________
Please mark this post as an "Accept as solution" in case if it helped to resolve your query. So that it will help to other forum users to directly refer to the answer.
Give kudos to this post in case if you think the information is useful and reply oriented.
FMC引脚支持高速。
以上来自于谷歌翻译
以下为原文
