Cypress技术william hill官网
徐非姗
7年用户 167经验值
16通道20位Delta Sigma ADC的数据缓冲带在PSOC 3和PSOC 5中工作
所附项目使用DMA实现Delta Sigma ADC的输出数据缓冲。
由于辐条宽度对于ADC等外围设备来说是16位的,所以我们需要两个独立的DMA来缓冲输出数据存储位置。ADC的输入通道选择是使用模拟MUX来完成的,它的选择线是由状态机驱动的。一旦当前ADC转换结束,模拟多路复用器的信道选择线将改变以连接下一个ADC的信道。
所附项目同时在PSoC 3和PSoC 5中工作。唯一不同的是PSoC 3在将ADC数据传送到存储器之前需要Endiad交换。
Delsig16Chhanel-20BIT-DMA-000 0.CyWrk.CaseV01.Zip
2.4兆字节
以上来自于百度翻译
     以下为原文
  The attached project implements Delta Sigma ADC's output data buffering using the DMA.
    Since the spoke width is of 16-bits for the peripherals like  ADC, we need two independent DMAs to buffer the output data in a memory location. The ADC's input channel selection is done using an Analog Mux whose select lines are driven by a state-machine. Once the current ADC conversion is over, Analog Mux's channel select lines will change to connect the next ADC's channel.
    The attached project works in both PSoC 3 and PSoC 5 as well. Only difference is that PSoC 3 requires endian swapping before transferring the ADC data to memory.
回帖(2)
王琳
2019-7-12 15:38:44
您可能在3之前使用创建者版本。上传的项目文件在创建者3下运行无错误。
鲍勃
以上来自于百度翻译
     以下为原文
  You are probably using a Creator version before 3.0. The uploaded project-file works error-free under Creator 3.0
    Bob
李恩佳
2019-7-12 15:53:35
谢谢Senthilnathan。Bob Marlowe还给了我们他的项目:APP=william hill官网 和RID=66562,现在我们可以选择和比较。遗憾的是,PSOC4中没有DMA((
以上来自于百度翻译
     以下为原文
          Thank Senthilnathan. Bob Marlowe also gave us his project: http://www.cypress.com/?app=forum&rID=66562 Now we can choose and compare. It is a pity that no DMA in PSoC4 (((
