该
http://www.st.com/web/en/catalog/tools/PF253187
用于与Sound Terminal评估套件通信,并要求第三方驱动程序正常运行。驱动程序可从http://www.ftdichip.com/Drivers/D2XX.htm获得
虽然FTDI驱动程序已包含在APWorkbench安装程序包中,但只有在实际的APWLink I / F通过USB连接到PC后才能完成安装。如果不发生这种情况,将禁用与此类I / F的通信。
请注意,APWorkbench仍然可以在仿真模式下运行(不与任何实际IC /设备通信)或通过http://www.st.com/web/en/catalog/tools/PF258331运行
, 如果可供使用的话。此外,建议使用STAudioHub接口进行ST MEMS麦克风评估。
以上来自于谷歌翻译
以下为原文
The
is used to communicate with Sound Terminal evaluation kits and requires a third-party driver to operate correctly. Driver is available from http://www.ftdichip.com/Drivers/D2XX.htm
Though FTDI driver is already included in the APWorkbench setup package its installation will be completed only once an actual APWLink I/F is connected to the PC, via USB. If this does not happen the communication with such I/F will be disabled.
Note that APWorkbench can still be operated either in simulation mode (no communication with any actual IC/device) or through an http://www.st.com/web/en/catalog/tools/PF258331
, if available. Also, STAudioHub interface is recommended for ST MEMS Microphone evaluation.
该
以上来自于谷歌翻译
以下为原文
The
