Cypress技术william hill官网
李晓欢
7年用户 192经验值
请问怎么根据执行函数的持续时间来定义中断的调用
大家好,
我有一个在中断中被调用的函数。我希望根据执行函数的持续时间来定义中断的调用。
正常地知道执行的持续时间,我在开始设置一个PIN,并在函数的末尾清除PIN。我看一个示波器的持续时间。
但是在家里我没有示波器。有没有简单的方法知道持续时间?我有一个UART发送数据
谢谢你
以上来自于百度翻译
     以下为原文
   Hi everyone,
    I have a function which is called in an interruption. I would like define the call of my interruption according to the duration of execution of my function.
    Normaly to know simply the duration of execution I set a pin at the begining and clear the pin at the end of the function. I look on a oscilloscope the duration.
    But at home I haven't osciloscope. Is there a simply method to know the duration? I have  a UART to send data
    Thank you
回帖(1)
李晓欢
2019-7-30 08:09:59
好的,谢谢,但我不明白。
如果我把时钟24mhz与一期256定时器(10667µS),当我站在我的功能的定时器,我怎么能有时间吗?我会得到计时器的计数器值。
谢谢您
以上来自于百度翻译
     以下为原文
   Okay thanks but I don't understand something,
    if I put a clock of 24MHZ on the timer with a period of 256 (10,667µS) , when I stop the timer in my function,how can I have the time? I will get the counter value of the timer
    thank you
