各位大神,小弟新使用MSP430F6726A做开发,遇到晶振不起振问题,头疼不已,还请各位大神指点迷津。
主要问题:使用32.768kHz晶振接MCU24,25管脚(XIN,XOUT),根据规格书使用12pF的匹配电容,晶振不起振,更换3pF,6pF,9pF,15pF,22pF,30pF,47pF匹配电容还是不起振,询问ti技术人员也没给出具体解决办法,基本上也是从PCB布线,电容匹配方面给分析的,但都已试过,没起作用,由于此款MCU自带晶振,外部晶振不起振会转到内部晶振起振,以下是源码部分从TI官网上弄得:
void Systerm_Clock_init(void)
volatile unsigned int i;
PJDIR |= BIT0 | BIT1 | BIT3; //ACLK, MCLK, SMCLK set out to pins
PJSEL |= BIT0 | BIT1 | BIT3; //PJ.0,1,3 for debugging purposes.
// Setup UCS
// Loop until XT1 fault flag is cleared
do
UCSCTL7 &= ~XT1LFOFFG; //Clear XT1 fault flags
} while (UCSCTL7 & XT1LFOFFG); //Test XT1 fault flag
UCSCTL6 &= ~(XT1OFF); //XT1 On
UCSCTL6 |= XCAP_3; //Internal load cap
__bic_SR_register(SCG0); // Enable the FLL control loop
UCSCTL0 = 0x0000; //Set lowest possible DCOx, MODx
UCSCTL1 = DCORSEL_5; //Select DCO range 16MHz operation
UCSCTL2 = FLLD_0 + 511; //(N + 1) * FLLRef = Fdco=(487 + 1) * 32768 =15990784Hz= 16MHz
__bic_SR_register(SCG0); //Enable the FLL control loop
__delay_cycles(600000); //32 x 32 x 16 MHz / 32,768 Hz = 500000 = MCLK cycles for DCO to settle
