基于树莓派3b+开发
import com.pi4j.io.gpio.GpioController;
import com.pi4j.io.gpio.GpioFactory;
import com.pi4j.io.gpio.GpioPinDigitalOutput;
import com.pi4j.io.gpio.PinState;
import com.pi4j.io.gpio.RaspiPin;
import java.util.Scanner;
public class test
//获取全局Gpio 引脚控制器对象
public static final GpioController gpio = GpioFactory.getInstance();
//定义编号为00/01/02/03引脚为数字输出引脚,初始化为低电平
public static final GpioPinDigitalOutput pin1output = gpio.provisionDigitalOutputPin(RaspiPin.GPIO_00, "" ,PinState.LOW);
public static final GpioPinDigitalOutput pin2output = gpio.provisionDigitalOutputPin(RaspiPin.GPIO_01, "" ,PinState.LOW);
public static final GpioPinDigitalOutput pin3output = gpio.provisionDigitalOutputPin(RaspiPin.GPIO_02, "" ,PinState.LOW);
public static final GpioPinDigitalOutput pin4output = gpio.provisionDigitalOutputPin(RaspiPin.GPIO_03, "" ,PinState.LOW);
public static void forward (int step)
s
基于树莓派3b+开发
public class test
//获取全局Gpio 引脚控制器对象
s
