golabs
8年用户 912经验值
擅长:可编程逻辑 电源/新能源 MEMS/传感技术 测量仪表
飞凌IMX6Q V1.3的底板给Linux3.0.35打上实时补丁后,运行吐核怎么办?
  • Unable to handle kernel NULL pointer dereference at virtual address 00000000
    pgd = 80004000
    [00000000] *pgd=00000000
    Internal error: Oops: 80000007 [#1] PREEMPT SMP
    Modules linked in:
    CPU: 0    Not tainted  (3.0.35-2666-gbdde708-rt*56 #8)
    PC is at 0x0
    LR is at activate_task+0x54/0x64
    pc : [<00000000>]    lr : [<8006d7bc>]    psr: 80000093
    sp : bff87eb8  ip : 00000000  fp : bff87ecc
    r10: 20000013  r9 : 8003c240  r8 : bff92cb8
    r7 : 00000008  r6 : 00000001  r5 : bff92920  r4 : 8c017240
    r3 : 00000000  r2 : 00000001  r1 : bff92920  r0 : 8c017240
    Flags: Nzcv  IRQs off  FIQs on  Mode SVC_32  ISA ARM  Segment kernel
    Control: 10c53c7d  Table: 4a5e804a  DAC: 00000015
    Process ksoftirqd/0 (pid: 3, stack limit = 0xbff862f0)
    Stack: (0xbff87eb8 to 0xbff88000)
    7ea0:                                                       00000001 bff92920
    7ec0: 8c017240 00000001 bff87efc 80072cfc 00000003 8003c240 00000000 80b3e520
    7ee0: 80b3e520 80ac6200 bff86000 00200200 00000000 00000000 803b59e0 8055855c
    7f00: bff87f10 80083514 00000000 bff86000 bff87f10 bff87f10 80b3e380 00000101
    7f20: 80ac6184 bff86000 80adfff8 80ac6180 00000000 80b3e380 00000001 8007c28c
    7f40: bffdf290 00000000 00000001 00000000 00000000 bff86000 8c00e2b8 00000000
    7f60: 80adfff8 8003b2b8 00000000 00000000 00000000 8007c448 bff86000 00000000
    7f80: 00000001 bff87f94 80b3e380 8007c55c 00000013 00000001 00000000 bff81f1c
    7fa0: 00000000 8007c4a0 00000013 00000000 00000000 800915b4 00000000 00000000
    7fc0: 00000000 00000000 00000000 bff87fcc bff87fcc 00000000 00000000 00000000
    7fe0: bff87fe0 bff87fe0 bff81f1c 80091534 80043a98 80043a98 02c10200 00510201
    [<8006d7bc>] (activate_task+0x54/0x64) from [<80072cfc>] (try_to_wake_up+0x26c/0x2f4)
    [<80072cfc>] (try_to_wake_up+0x26c/0x2f4) from [<8055855c>] (rt_spin_lock_slowunlock+0x24/0x54)
    [<8055855c>] (rt_spin_lock_slowunlock+0x24/0x54) from [<80083514>] (run_timer_softirq+0x170/0x240)
    [<80083514>] (run_timer_softirq+0x170/0x240) from [<8007c28c>] (__do_softirq_common+0xc4/0x178)
    [<8007c28c>] (__do_softirq_common+0xc4/0x178) from [<8007c448>] (__thread_do_softirq+0x108/0x160)
    [<8007c448>] (__thread_do_softirq+0x108/0x160) from [<8007c55c>] (run_ksoftirqd+0xbc/0x180)
    [<8007c55c>] (run_ksoftirqd+0xbc/0x180) from [<800915b4>] (kthread+0x80/0x88)
    [<800915b4>] (kthread+0x80/0x88) from [<80043a98>] (kernel_thread_exit+0x0/0x8)
    Code: bad PC value
    飞凌的IMX6Q V1.3的底板,给Linux3.0.35打上实时补丁后,运行吐核,请问有遇到的么,或者解决思路
回帖(1)
徐静怡
2022-1-7 10:05:43
  • 抱歉我们目前没有打实时补丁的方法,我们自己也没有这么操作过。
    您可以看william hill官网 里有没有其他用户尝试过,帮您解答一下。
