刘伟
7年用户 1637经验值
如何对基于RK3288平台的Simple card声卡进行调试呢
基于RK3288平台的Simple card声卡该怎样去添加呢?
如何对基于RK3288平台的Simple card声卡进行调试呢?
回帖(1)
张玉华
2022-3-3 15:41:25
基于RK3288 平台 Simple card声卡添加及调试
Simple card即简单通用的machine driver, 如果simple-card框架足够满足需求,建议优先使用simple card框架,简单,方便,且易用.
一、 添加声卡
1. 添加codec driver,比如添加:sound/soc/codec/es8323.c
2. 修改sound/soc/codec/Kconfig以及Makefile加入驱动编译。
sound/soc/codec/Kconfig: 添加
select SND_SOC_ES8323 if I2C
config SND_SOC_ES8323
        tristate "Everest Semi ES8323 CODEC"
        depends on I2C
sound/soc/codec/Makefile: 添加
snd-soc-es8323-objs := es8323.o
obj-$(CONFIG_SND_SOC_ES8323)    += snd-soc-es8323.o
3. menuconfig中enable simple card以及codec
make menuconfig Device Drivers ---> Sound card support --->  Advanced Linux Sound Architecture --->  ALSA for SoC audio support --->  ASoC support for Rockchip
CODEC drivers  --->
<*> Everest Semi ES8323 CODEC
4. 产品的DTS中添加Simple Card Node
二、修改DTS文件
1 添加sound card 和 spdif(可选添加,用不到不用添加)
2 添加:&i2c2(es8323 mclk)和&i2s(es8323 I2S通信)
3 添加&sound
  注意,需要增加内容如下:
sound: sound {
                status = "okay";
                compatible = "simple-audio-card";
                simple-audio-card,format = "i2s";
                simple-audio-card,name = "rockchip,firefly-codec";
                simple-audio-card,mclk-fs = <512>;
                simple-audio-card,widgets =
                        "Microphone", "Microphone Jack",
                        "Headphone", "Headphone Jack";
                simple-audio-card,routing =
                        "MIC1", "Microphone Jack",
                        "MIC2", "Microphone Jack",
                        "Microphone Jack", "micbias1",
                        "Headphone Jack", "HPOL",
                        "Headphone Jack", "HPOR";
                simple-audio-card,dai-link@0 {
                        format = "i2s";
                        cpu {
                                sound-dai = <&i2s>;
                        codec {
                                sound-dai = <&es8323>;
                simple-audio-card,dai-link@1 {
                        format = "i2s";
                        cpu {
                                sound-dai = <&i2s>;
                        codec {
                                sound-dai = <&hdmi>;
         spdif_out: spdif-out {
                status = "okay";
                compatible = "linux,spdif-dit";
                #sound-dai-cells = <0>;
        spdif-sound {
                status = "okay";
                simple-audio-card,name = "ROCKCHIP,SPDIF";
                simple-audio-card,cpu {
                        sound-dai = <&spdif>;
                simple-audio-card,codec {
                        sound-dai = <&spdif_out>;
&i2c2 {
        status = "okay";
        es8323: es8323@10 {
                status = "okay";
                compatible = "everest,es8323";
                reg = <0x10>;
                spk-con-gpio = <&gpio5 12 GPIO_ACTIVE_LOW>;
//              hp-det-gpio = <&gpio7 15 GPIO_ACTIVE_LOW>;
                clock-names = "mclk";
                clocks = <&cru SCLK_I2S0_OUT>;
                pinctrl-names = "default";
                pinctrl-0 = <&i2s0_mclk>;
需要注意的是,如上es8323的clocks即mclk, upstream代码遵循谁使用clk谁申请的原则,所以后续自己添加的codec driver,如果有使用
外部clk作为mclk,需要做同样的适配。
&i2s {
        status = "okay";
&sound {
        status = "okay";
注意要去掉以下内容,否则声卡驱动无法挂载
&es8323 {
//      aux-det-gpio = <&gpio2 15 GPIO_ACTIVE_HIGH>;
        spk-ctl-gpio = <&gpio7 2 GPIO_ACTIVE_HIGH>;
三、总结
1 屏幕不亮的问题
  调试中发现屏幕 背光是亮的,但是屏幕不亮,把vcc_sys_5v: vcc-sys-5v,gpio GPIO0_B5 修改为GPIO7_A3屏幕就亮了。
如下所示:
        vcc_sys_5v: vcc-sys-5v{
                compatible = "regulator-fixed";
                enable-active-high;
                gpio = <&gpio7 3 GPIO_ACTIVE_HIGH>;
                pinctrl-0 = <&pwr5v_en>;
                regulator-name = "vcc_sys_5v";
                regulator-min-microvolt = <5000000>;
                regulator-max-microvolt = <5000000>;
                regulator-always-on;
                regulator-boot-on;
        vcc-sys {
                pwr5v_en: pwr5v-en {
                        rockchip,pins = <7 3 RK_FUNC_GPIO &pcfg_output_high>;
2 调试中声卡总是挂载不上去:在dts中去掉以下内容后就可以了。因为在I2C2中已经设置过
&es8323 {
