陈勇
7年用户 1257经验值
如何查询HDMI驱动相关代码?
如何查询HDMI驱动相关代码?
回帖(1)
马秀英
2022-3-7 09:54:54
0 前言
   刚买的HDMI没有配DSI接口的屏幕,大多数情况下使用的是HDMI屏幕,所以搞清楚HDMI驱动对后面的学习很有必要。
1 HDMI驱动相关代码查询
    要想找到HDMI驱动位置,先编译一遍kernel,然后找相关的.o文件:
zhu@zhu-VirtualBox:~/Work/Projects/rk3399/srcs/Android-8.1/android/kernel/drivers$ find -name *hdmi*.o
./gpu/drm/rockchip/dw_hdmi-rockchip.o
./gpu/drm/rockchip/inno_hdmi.o
./gpu/drm/bridge/synopsys/dw-hdmi-hdcp.o
./gpu/drm/bridge/synopsys/dw-hdmi.o
./gpu/drm/bridge/synopsys/dw-hdmi-cec.o
./gpu/drm/bridge/synopsys/dw-hdmi-i2s-audio.o
./video/hdmi.o
./video/hdmi-notifier.o
./phy/rockchip/phy-rockchip-inno-hdmi-phy.o
2 驱动接口分析
不管是HDMI还是DSI接口的屏,最后都会使用DRM框架的crtc来操作,先grep下file_operations结构体:
2.1 在./gpu/drm/rockchip/下grep
rockchip_drm_drv.c:1658:static const struct file_operations rockchip_drm_driver_fops = {
进去看看其对应的驱动设备,这应该就是DRM驱动接口,里面的ioctl是给libdrm使用的,填图刷图在里面。
    .owner = THIS_MODULE,
    .open = drm_open,
    .mmap = rockchip_gem_mmap,
    .poll = drm_poll,
    .read = drm_read,
    .unlocked_ioctl = drm_ioctl,
#ifdef CONFIG_COMPAT
    .compat_ioctl = drm_compat_ioctl,
#endif
    .release = drm_release,
  一个DRM驱动一定有一个drm_driver结构体:
static struct drm_driver rockchip_drm_driver = {
    .driver_features    = DRIVER_MODESET | DRIVER_GEM |
                  DRIVER_PRIME | DRIVER_ATOMIC |
                  DRIVER_RENDER,  // 告诉 DRM Core 当前驱动支持 modeset/gem等操作
    .preclose       = rockchip_drm_preclose,
    .lastclose      = rockchip_drm_lastclose,
    .get_vblank_counter = drm_vblank_no_hw_counter,
    .open           = rockchip_drm_open,
    .postclose      = rockchip_drm_postclose,
    .enable_vblank      = rockchip_drm_crtc_enable_vblank,
    .disable_vblank     = rockchip_drm_crtc_disable_vblank,
    .gem_vm_ops     = &rockchip_drm_vm_ops,
    .gem_free_object    = rockchip_gem_free_object,
    .dumb_create        = rockchip_gem_dumb_create,   // 创建buffer
    .dumb_map_offset    = rockchip_gem_dumb_map_offset, // mmap buffer
    .dumb_destroy       = drm_gem_dumb_destroy,
    .prime_handle_to_fd = drm_gem_prime_handle_to_fd,
    .prime_fd_to_handle = drm_gem_prime_fd_to_handle,
    .gem_prime_import   = drm_gem_prime_import,
    .gem_prime_export   = drm_gem_prime_export,
    .gem_prime_get_sg_table = rockchip_gem_prime_get_sg_table,
    .gem_prime_import_sg_table  = rockchip_gem_prime_import_sg_table,
    .gem_prime_vmap     = rockchip_gem_prime_vmap,
    .gem_prime_vunmap   = rockchip_gem_prime_vunmap,
    .gem_prime_mmap     = rockchip_gem_mmap_buf,
    .gem_prime_begin_cpu_access = rockchip_gem_prime_begin_cpu_access,
    .gem_prime_end_cpu_access = rockchip_gem_prime_end_cpu_access,
#ifdef CONFIG_DEBUG_FS
    .debugfs_init       = rockchip_drm_debugfs_init,
    .debugfs_cleanup    = rockchip_drm_debugfs_cleanup,
#endif
    .ioctls         = rockchip_ioctls,
    .num_ioctls     = ARRAY_SIZE(rockchip_ioctls),
    .fops           = &rockchip_drm_driver_fops,  // 对应上面的fops
    .name   = DRIVER_NAME,
    .desc   = DRIVER_DESC,
    .date   = DRIVER_DATE,
    .major  = DRIVER_MAJOR,
    .minor  = DRIVER_MINOR,
  DRM初始化过程:
rockchip_drm_platform_probe  // 驱动入口 @kernel/drivers/gpu/drm/rockchip/rockchip_drm_drv.c
|-->component_master_add_with_match(dev, &rockchip_drm_ops, match) // @kernel-4.14/drivers/base/component.c
    |-->try_to_bring_up_master
        |-->master->ops->bind(master->dev)
            |-->rockchip_drm_bind // @kernel/drivers/gpu/drm/rockchip/rockchip_drm_drv.c
                |-->drm_dev = drm_dev_alloc(&rockchip_drm_driver, dev) // struct drm_device * drm_dev @kernel/drivers/gpu/drm/drm_drv.c 分配并初始化一个DRM设备
                // drm_dev->driver = rockchip_drm_driver
                |-->rockchip_drm_init_iommu
                |-->drm_mode_config_init(drm_dev) // @kernel/drivers/gpu/drm/drm_crtc.c
                |   |-->drm_mode_create_standard_properties(dev) // 创建DRM属性
                |-->rockchip_drm_mode_config_init(drm_dev)  // 设置fb的最大最小宽高
                |-->rockchip_drm_create_properties(drm_dev)  // 创建CABC等属性
                |-->component_bind_all(dev, drm_dev) //Try to bind all sub drivers
                |-->rockchip_attach_connector_property(drm_dev) // 对于每个connector, 亮度、饱和度、对比度、色调都设置为100
                |-->drm_vblank_init(drm_dev, drm_dev->mode_config.num_crtc) // 初始化vblank
                |-->drm_mode_config_reset(drm_dev)
                |-->rockchip_drm_set_property_default(drm_dev) // 对于每个connector, 亮度、饱和度、对比度、色调都设置为50
                |-->drm_dev->irq_enabled = true // 可以使用vblank feature
                |-->drm_kms_helper_poll_init(drm_dev)
                |-->drm_dev->vblank_disable_allowed = true  // vblank中断disable
                |-->rockchip_gem_pool_init(drm_dev)
                |-->of_reserved_mem_device_init(drm_dev->dev)
                |-->rockchip_drm_fbdev_init(drm_dev)
                |-->drm_dev_register(drm_dev, 0) // 注册drm设备
                    |-->drm_minor_register(dev, DRM_MINOR_CONTROL)
                    |-->drm_minor_register(dev, DRM_MINOR_RENDER)
                    |-->drm_minor_register(dev, DRM_MINOR_PRIMARY)
                    |-->dev->driver->load(dev, flags)
  还有1个很重要的结构体:
static const struct drm_mode_config_funcs rockchip_drm_mode_config_funcs = {
    .fb_create = rockchip_user_fb_create,   // 创建buffer
    .output_poll_changed = rockchip_drm_output_poll_changed,
    .atomic_check = drm_atomic_helper_check,
    .atomic_commit = rockchip_drm_atomic_commit,  // 属性生效
2.2 在./gpu/drm/bridge/synopsys/下grep
dw-hdmi.c:3264:static const struct file_operations dw_hdmi_status_fops = {
dw-hdmi.c:3354:static const struct file_operations dw_hdmi_ctrl_fops = {
dw-hdmi.c:3404:static const struct file_operations dw_hdmi_phy_fops = {
以上三个fops都是debugfs文件节点操作函数:在/d/dw-hdmi/status、/d/dw-hdmi/ctrl和/d/dw-hdmi/phy
  所以他们应该是用来调试的,其中dw_hdmi_ctrl_fops中的write可以用来写寄存器:
static ssize_t
dw_hdmi_ctrl_write(struct file *file, const char __user *buf,
           size_t count, loff_t *ppos)
    struct dw_hdmi *hdmi =
        ((struct seq_file *)file->private_data)->private;
    u32 reg, val;
    char kbuf[25];
    if (hdmi->dev_type == RK3228_HDMI)
        return -EFAULT;
    if (copy_from_user(kbuf, buf, count))
        return -EFAULT;
    if (sscanf(kbuf, "%x%x", ®, &val) == -1)
        return -EFAULT;
    if ((reg < 0) || (reg > HDMI_I2CM_FS_SCL_LCNT_0_ADDR)) {
        dev_err(hdmi->dev, "it is no a hdmi registern");
        return count;
    dev_info(hdmi->dev, "/**********hdmi register config******/");
    dev_info(hdmi->dev, "n reg=%x val=%xn", reg, val);
    hdmi_writeb(hdmi, val, reg);
    return count;
dw_hdmi_phy_fops中的write可以用来写寄存器:
static ssize_t
dw_hdmi_phy_write(struct file *file, const char __user *buf,
    u32 reg, val;
    char kbuf[25];
        return -EFAULT;
        return -EFAULT;
    if ((reg < 0) || (reg > 0x100)) {
        dev_err(hdmi->dev, "it is not a hdmi phy registern");
        return count;
    dev_info(hdmi->dev, "/*******hdmi phy register config******/");
    dw_hdmi_phy_i2c_write(hdmi, val, reg);
    return count;
  那么上面写的HDMI相关寄存器到底是啥?
  根据read系统调用(read使用到了seq_file方法[5]),grep 寄存器宏定义得到:
#define HDMI_FC_DRM_UP              0x1167
#define HDMI_FC_DRM_HB0             0x1168
#define HDMI_FC_DRM_HB1             0x1169
#define HDMI_FC_DRM_PB0             0x116a
#define HDMI_FC_DRM_PB1             0x116b
#define HDMI_FC_DRM_PB2             0x116c
#define HDMI_FC_DRM_PB3             0x116d
#define HDMI_FC_DRM_PB4             0x116e
#define HDMI_FC_DRM_PB5             0x116f
#define HDMI_FC_DRM_PB6             0x1170
#define HDMI_FC_DRM_PB7             0x1171
#define HDMI_FC_DRM_PB8             0x1172
#define HDMI_FC_DRM_PB9             0x1173
#define HDMI_FC_DRM_PB10            0x1174
#define HDMI_FC_DRM_PB11            0x1175
#define HDMI_FC_DRM_PB12            0x1176
#define HDMI_FC_DRM_PB13            0x1177
#define HDMI_FC_DRM_PB14            0x1178
#define HDMI_FC_DRM_PB15            0x1179
#define HDMI_FC_DRM_PB16            0x117a
#define HDMI_FC_DRM_PB17            0x117b
#define HDMI_FC_DRM_PB18            0x117c
#define HDMI_FC_DRM_PB19            0x117d
#define HDMI_FC_DRM_PB20            0x117e
#define HDMI_FC_DRM_PB21            0x117f
#define HDMI_FC_DRM_PB22            0x1180
#define HDMI_FC_DRM_PB23            0x1181
#define HDMI_FC_DRM_PB24            0x1182
#define HDMI_FC_DRM_PB25            0x1183
#define HDMI_FC_DRM_PB26            0x1184
