| VS-RK3288板卡HDMI显示uboot和kernel的logo图片 修改uboot源码: include/configs/rk32plat.h #define CONFIG_ROCKCHIP_MIPI_DSI #define CONFIG_ROCKCHIP_DW_MIPI_DSI #define CONFIG_ROCKCHIP_ANALOGIX_DP +#define CONFIG_DRM_ROCKCHIP_DW_HDMI #define CONFIG_ROCKCHIP_PANEL #define CONFIG_I2C_EDID #endif 修改kernel源码: /arch/arm/boot/dts/rk3288-android.dtsi connect = <&vopl_out_edp>; }; + route_hdmi: route-hdmi { + status = "disabled"; + logo,uboot = "logo.bmp"; + logo,kernel = "logo_kernel.bmp"; + logo,mode = "center"; + charge_logo,mode = "center"; + connect = <&vopb_out_hdmi>; + }; + route_dsi0: route-dsi0 { status = "disabled"; logo,uboot = "logo.bmp"; /arch/arm/boot/dts/rk3288-evb-android-rk808-mipi.dts status = "okay"; }; +&route_hdmi { + status = "okay"; + connect = <&vopb_out_hdmi>; +}; + &gpu { status = "okay"; mali-supply = <&vdd_gpu>; -- /drivers/clk/rockchip/clk-rk3288.c [cpll] = PLL(pll_rk3066, PLL_CPLL, "cpll", mux_pll_p, 0, RK3288_PLL_CON(8), RK3288_MODE_CON, 8, 7, 0, rk3288_pll_rates), [gpll] = PLL(pll_rk3066, PLL_GPLL, "gpll", mux_pll_p, 0, RK3288_PLL_CON(12), - RK3288_MODE_CON, 12, 8, ROCKCHIP_PLL_SYNC_RATE, rk3288_pll_rates), + RK3288_MODE_CON, 12, 8, 0, rk3288_pll_rates), [npll] = PLL(pll_rk3066, PLL_NPLL, "npll", mux_pll_p, 0, RK3288_PLL_CON(16), RK3288_MODE_CON, 14, 9, ROCKCHIP_PLL_SYNC_RATE, rk3288_pll_rates), }; -- 重新编译uboot和kernel,烧录并测试。 |
