王霞
7年用户 1349经验值
怎么去解决RK3288系统电池的电量显示为100%的问题呢
怎么去解决RK3288系统电池的电量显示为100%的问题呢?
回帖(2)
王璐
2022-3-10 13:46:29
Platform: Rockchip
OS: Android 6.0
Kernel: 3.10.92
之前文章[RK3288][Android6.0] 调试笔记 — 伪电池驱动添加 阐述了如何添加一个假的电池驱动,
测试发现Setting里的电池电量一直是100%
跟踪发现Android6.0相比之前的Android4.4会判断Charger是否存在,不存在就认为设备不具备充电能力并且设定当前电量是100%
解决方法:
kris@:~/rk3288/system/core/healthd$ g df 6446f0e6bfabeee8cbe8b233bf7bf87ad7b55665 727c2d4ab5c4b50555b8c64d1b2a61a342e4360c
diff --git a/healthd/BatteryMonitor.cpp b/healthd/BatteryMonitor.cpp
index 07e7a18..396dfef 100644
--- a/healthd/BatteryMonitor.cpp
+++ b/healthd/BatteryMonitor.cpp
@@ -555,18 +555,12 @@ void BatteryMonitor::init(struct healthd_config *hc) {
     // This indicates that there is no charger driver registered.
     // Typically the case for devices which do not have a battery and
     // and are always plugged into AC mains.
-/*Kris, 20170728, we don't have any charger. { */
-#if 0
     if (!mChargerNames.size()) {
         KLOG_ERROR(LOG_TAG, "No charger supplies foundn");
         mBatteryFixedCapacity = ALWAYS_PLUGGED_CAPACITY;
         mBatteryFixedTemperature = FAKE_BATTERY_TEMPERATURE;
         mAlwaysPluggedDevice = true;
-#endif
-/*Kris, 20170728, we don't have any charger. } */
     if (!mBatteryDevicePresent) {
         KLOG_WARNING(LOG_TAG, "No battery devices foundn");
         hc->periodic_chores_interval_fast = -1;
庄金樱
2022-3-10 13:49:36
Platform: Rockchip
OS: Android 6.0
Kernel: 3.10.92
解决方法:
-#if 0
-#endif
