drv_rtc.c 代码,供参考
- #include "board.h"
- #include
- #include
- #ifdef BSP_USING_ONCHIP_RTC
- struct rt_rtc_device
- struct rt_device device;
- #ifdef RT_USING_ALARM
- struct rt_rtc_wkalarm wkalarm;
- #endif
- #define DBG_ENABLE
- #define DBG_SECTION_NAME "drv_rtc"
- #define DBG_LEVEL DBG_INFO
- #include
- static struct rt_rtc_device rtc_device;
- static rt_err_t rtc_alarm_time_set(struct rt_rtc_device* p_dev);
- static int rt_rtc_alarm_init(void);
- static RTC_AlarmTypeDef salarmstructure;
- #endif
- #ifndef RTC_BKP_DR1
- #define RTC_BKP_DR1 RT_NULL
- #endif
- #define BKUP_REG_DATA 0xA5A5
- static RTC_HandleTypeDef RTC_Handler;
- RT_WEAK uint32_t HAL_RTCEx_BKUPRead(RTC_HandleTypeDef *hrtc, uint32_t BackupRegister)
- return (~BKUP_REG_DATA);
- RT_WEAK void HAL_RTCEx_BKUPWrite(RTC_HandleTypeDef *hrtc, uint32_t BackupRegister, uint32_t Data)
- return;
- static time_t get_rtc_timestamp(void)
- RTC_TimeTypeDef RTC_TimeStruct = {0};
- RTC_DateTypeDef RTC_DateStruct = {0};
- struct tm tm_new = {0};
- HAL_RTC_GetTime(&RTC_Handler, &RTC_TimeStruct, RTC_FORMAT_BIN);
- HAL_RTC_GetDate(&RTC_Handler, &RTC_DateStruct, RTC_FORMAT_BIN);
- tm_new.tm_sec = RTC_TimeStruct.Seconds;
- tm_new.tm_min = RTC_TimeStruct.Minutes;
- tm_new.tm_hour = RTC_TimeStruct.Hours;
- tm_new.tm_mday = RTC_DateStruct.Date;
- tm_new.tm_mon = RTC_DateStruct.Month - 1;
- tm_new.tm_year = RTC_DateStruct.Year + 100;
- return mktime(&tm_new);
- static rt_err_t set_rtc_time_stamp(time_t time_stamp)
- struct tm *p_tm;
- p_tm = localtime(&time_stamp);
- if (p_tm->tm_year < 100)
- return -RT_ERROR;
- RTC_TimeStruct.Seconds = p_tm->tm_sec ;
- RTC_TimeStruct.Minutes = p_tm->tm_min ;
- RTC_TimeStruct.Hours = p_tm->tm_hour;
- RTC_DateStruct.Date = p_tm->tm_mday;
- RTC_DateStruct.Month = p_tm->tm_mon + 1 ;
- RTC_DateStruct.Year = p_tm->tm_year - 100;
- RTC_DateStruct.WeekDay = p_tm->tm_wday + 1;
- if (HAL_RTC_SetTime(&RTC_Handler, &RTC_TimeStruct, RTC_FORMAT_BIN) != HAL_OK)
- return -RT_ERROR;
- if (HAL_RTC_SetDate(&RTC_Handler, &RTC_DateStruct, RTC_FORMAT_BIN) != HAL_OK)
- return -RT_ERROR;
- LOG_D("set rtc time.");
- HAL_RTCEx_BKUPWrite(&RTC_Handler, RTC_BKP_DR1, BKUP_REG_DATA);
- #ifdef SOC_SERIES_STM32F1
- /* F1 series does't save year/month/date datas. so keep those datas to bkp reg */
- HAL_RTCEx_BKUPWrite(&RTC_Handler, RTC_BKP_DR2, RTC_DateStruct.Year);
- HAL_RTCEx_BKUPWrite(&RTC_Handler, RTC_BKP_DR3, RTC_DateStruct.Month);
- HAL_RTCEx_BKUPWrite(&RTC_Handler, RTC_BKP_DR4, RTC_DateStruct.Date);
- HAL_RTCEx_BKUPWrite(&RTC_Handler, RTC_BKP_DR5, RTC_DateStruct.WeekDay);
- #endif
- return RT_EOK;
- static void rt_rtc_init(void)
- #if !defined(SOC_SERIES_STM32H7) && !defined(SOC_SERIES_STM32WB)
- __HAL_RCC_PWR_CLK_ENABLE();
- #endif
- RCC_OscInitTypeDef RCC_OscInitStruct = {0};
- #ifdef BSP_RTC_USING_LSI
- #ifdef SOC_SERIES_STM32WB
- RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_LSI1;
- RCC_OscInitStruct.PLL.PLLState = RCC_PLL_NONE;
- RCC_OscInitStruct.LSEState = RCC_LSE_OFF;
- RCC_OscInitStruct.LSIState = RCC_LSI_ON;
- #else
- RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_LSI;
- #endif
- #else
- RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_LSE;
- RCC_OscInitStruct.LSEState = RCC_LSE_ON;
- RCC_OscInitStruct.LSIState = RCC_LSI_OFF;
- #endif
- HAL_RCC_OscConfig(&RCC_OscInitStruct);
- /* update RTC_BKP_DRx*/
- static void rt_rtc_f1_bkp_update(void)
- HAL_PWR_EnableBkUpAccess();
- __HAL_RCC_BKP_CLK_ENABLE();
- RTC_DateStruct.Year = HAL_RTCEx_BKUPRead(&RTC_Handler, RTC_BKP_DR2);
- RTC_DateStruct.Month = HAL_RTCEx_BKUPRead(&RTC_Handler, RTC_BKP_DR3);
- RTC_DateStruct.Date = HAL_RTCEx_BKUPRead(&RTC_Handler, RTC_BKP_DR4);
- RTC_DateStruct.WeekDay = HAL_RTCEx_BKUPRead(&RTC_Handler, RTC_BKP_DR5);
- Error_Handler();
- if (HAL_RTCEx_BKUPRead(&RTC_Handler, RTC_BKP_DR4) != RTC_DateStruct.Date)
- #endif
- static rt_err_t rt_rtc_config(struct rt_device *dev)
- RCC_PeriphCLKInitTypeDef PeriphClkInitStruct = {0};
- PeriphClkInitStruct.PeriphClockSelection = RCC_PERIPHCLK_RTC;
- PeriphClkInitStruct.RTCClockSelection = RCC_RTCCLKSOURCE_LSI;
- #else
- PeriphClkInitStruct.RTCClockSelection = RCC_RTCCLKSOURCE_LSE;
- #endif
- HAL_RCCEx_PeriphCLKConfig(&PeriphClkInitStruct);
- /* Enable RTC Clock */
- __HAL_RCC_RTC_ENABLE();
- RTC_Handler.Instance = RTC;
- if (HAL_RTCEx_BKUPRead(&RTC_Handler, RTC_BKP_DR1) != BKUP_REG_DATA)
- LOG_I("RTC hasn't been configured, please use command to config.");
- #if defined(SOC_SERIES_STM32F1)
- RTC_Handler.Init.OutPut = RTC_OUTPUTSOURCE_NONE;
- RTC_Handler.Init.AsynchPrediv = RTC_AUTO_1_SECOND;
- #elif defined(SOC_SERIES_STM32F0)
- /* set the frequency division */
- RTC_Handler.Init.AsynchPrediv = 0XA0;
- RTC_Handler.Init.SynchPrediv = 0xFA;
- #else
- RTC_Handler.Init.AsynchPrediv = 0X7F;
- RTC_Handler.Init.SynchPrediv = 0x0130;
- #endif /* BSP_RTC_USING_LSI */
- RTC_Handler.Init.HourFormat = RTC_HOURFORMAT_24;
- RTC_Handler.Init.OutPut = RTC_OUTPUT_DISABLE;
- RTC_Handler.Init.OutPutPolarity = RTC_OUTPUT_POLARITY_HIGH;
- RTC_Handler.Init.OutPutType = RTC_OUTPUT_TYPE_OPENDRAIN;
- #elif defined(SOC_SERIES_STM32F2) || defined(SOC_SERIES_STM32F4) || defined(SOC_SERIES_STM32F7) || defined(SOC_SERIES_STM32L4) || defined(SOC_SERIES_STM32H7) || defined (SOC_SERIES_STM32WB)
- RTC_Handler.Init.AsynchPrediv = 0X7D;
- #else
- RTC_Handler.Init.SynchPrediv = 0XFF;
- #endif
- if (HAL_RTC_Init(&RTC_Handler) != HAL_OK)
- return -RT_ERROR;
- else
- /* F1 series need update by bkp reg datas */
- rt_rtc_f1_bkp_update();
- #endif
- return RT_EOK;
- static rt_err_t rt_rtc_control(rt_device_t dev, int cmd, void *args)
- rt_err_t result = RT_EOK;
- struct rt_rtc_wkalarm *p_wkalarm = RT_NULL;
- #endif
- RT_ASSERT(dev != RT_NULL);
- switch (cmd)
- case RT_DEVICE_CTRL_RTC_GET_TIME:
- *(rt_uint32_t *)args = get_rtc_timestamp();
- LOG_D("RTC: get rtc_time %xn", *(rt_uint32_t *)args);
- break;
- case RT_DEVICE_CTRL_RTC_SET_TIME:
- if (set_rtc_time_stamp(*(rt_uint32_t *)args))
- result = -RT_ERROR;
- rt_alarm_update(&rtc_device.device, 1);
- #endif
- LOG_D("RTC: set rtc_time %xn", *(rt_uint32_t *)args);
- break;
- case RT_DEVICE_CTRL_RTC_GET_ALARM:
- args = &rtc_device.wkalarm;
- LOG_D("GET_ALARM %d:%d:%d",rtc_device.wkalarm.tm_hour,
- rtc_device.wkalarm.tm_min,rtc_device.wkalarm.tm_sec);
- break;
- case RT_DEVICE_CTRL_RTC_SET_ALARM:
- LOG_D("RT_DEVICE_CTRL_RTC_SET_ALARM");
- p_wkalarm = (struct rt_rtc_wkalarm *)args;
- if (p_wkalarm != RT_NULL)
- rtc_device.wkalarm.enable = p_wkalarm->enable;
- rtc_device.wkalarm.tm_hour = p_wkalarm->tm_hour;
- rtc_device.wkalarm.tm_min = p_wkalarm->tm_min;
- rtc_device.wkalarm.tm_sec = p_wkalarm->tm_sec;
- rtc_alarm_time_set(&rtc_device);
- else
- LOG_E("RT_DEVICE_CTRL_RTC_SET_ALARM error!!");
- LOG_D("SET_ALARM %d:%d:%d",p_wkalarm->tm_hour,
- p_wkalarm->tm_min,p_wkalarm->tm_sec);
- break;
- #endif
- return result;
- #ifdef RT_USING_DEVICE_OPS
- const static struct rt_device_ops rtc_ops =
- RT_NULL,
- RT_NULL,
- RT_NULL,
- RT_NULL,
- RT_NULL,
- rt_rtc_control
- #endif
- static rt_err_t rt_hw_rtc_register(rt_device_t device, const char *name, rt_uint32_t flag)
- RT_ASSERT(device != RT_NULL);
- rt_rtc_init();
- if (rt_rtc_config(device) != RT_EOK)
- return -RT_ERROR;
- device->ops = &rtc_ops;
- #else
- device->init = RT_NULL;
- device->open = RT_NULL;
- device->close = RT_NULL;
- device->read = RT_NULL;
- device->write = RT_NULL;
- device->control = rt_rtc_control;
- #endif
- device->type = RT_Device_Class_RTC;
- device->rx_indicate = RT_NULL;
- device->tx_complete = RT_NULL;
- device->user_data = RT_NULL;
- /* register a character device */
- return rt_device_register(device, name, flag);
- int rt_hw_rtc_init(void)
- rt_err_t result;
- result = rt_hw_rtc_register(&rtc_device.device, "rtc", RT_DEVICE_FLAG_RDWR);
- if (result != RT_EOK)
- LOG_E("rtc register err code: %dn", result);
- return result;
- rt_rtc_alarm_init();
- #endif
- LOG_D("rtc init successn");
- return RT_EOK;
- void rt_rtc_alarm_enable(void)
- HAL_RTC_SetAlarm_IT(&RTC_Handler,&salarmstructure,RTC_FORMAT_BIN);
- HAL_RTC_GetAlarm(&RTC_Handler,&salarmstructure,RTC_ALARM_A,RTC_FORMAT_BIN);
- LOG_D("alarm read:%d:%d:%d", salarmstructure.AlarmTime.Hours,
- salarmstructure.AlarmTime.Minutes,
- salarmstructure.AlarmTime.Seconds);
- HAL_NVIC_SetPriority(RTC_Alarm_IRQn, 0x02, 0);
- HAL_NVIC_EnableIRQ(RTC_Alarm_IRQn);
- void rt_rtc_alarm_disable(void)
- HAL_RTC_DeactivateAlarm(&RTC_Handler, RTC_ALARM_A);
- HAL_NVIC_DisableIRQ(RTC_Alarm_IRQn);
- return RT_EOK;
- if (p_dev->wkalarm.enable)
- salarmstructure.Alarm = RTC_ALARM_A;
- salarmstructure.AlarmDateWeekDay = RTC_WEEKDAY_MONDAY;
- salarmstructure.AlarmDateWeekDaySel = RTC_ALARMDATEWEEKDAYSEL_WEEKDAY;
- salarmstructure.AlarmMask = RTC_ALARMMASK_DATEWEEKDAY;
- salarmstructure.AlarmSubSecondMask = RTC_ALARMSUBSECONDMASK_NONE;
- salarmstructure.AlarmTime.TimeFormat = RTC_HOURFORMAT12_AM;
- salarmstructure.AlarmTime.Hours = p_dev->wkalarm.tm_hour;
- salarmstructure.AlarmTime.Minutes = p_dev->wkalarm.tm_min;
- salarmstructure.AlarmTime.Seconds = p_dev->wkalarm.tm_sec;
- LOG_D("alarm set:%d:%d:%d", salarmstructure.AlarmTime.Hours,
- rt_rtc_alarm_enable();
- return RT_EOK;
- void HAL_RTC_AlarmAEventCallback(RTC_HandleTypeDef *hrtc)
- //LOG_D("rtc alarm isr.n");
- void RTC_Alarm_IRQHandler(void)
- HAL_RTC_AlarmIRQHandler(&RTC_Handler);
- #endif
- INIT_DEVICE_EXPORT(rt_hw_rtc_init);
- #endif /* BSP_USING_ONCHIP_RTC */
RTC_Alarm 测试代码,供参考
- #include
- #include
- #include
- #define RTC_DEBUG
- #define DBG_SECTION_NAME "rtc.test"
- #define DBG_LEVEL DBG_LOG
- #include
- #ifdef RTC_DEBUG
- static struct rt_alarm * p_alarm_sec = RT_NULL;
- static struct rt_alarm * p_alarm_min = RT_NULL;
- static struct rt_alarm * p_alarm_hour = RT_NULL;
- static struct rt_alarm * p_alarm_time = RT_NULL;
- static rt_err_t rtc_set_time(time_t timestamp)
- /* converts the local time in time to calendar time. */
- rt_device_t rtc_device;
- rt_err_t ret = -RT_ERROR;
- rtc_device = rt_device_find("rtc");
- if (rtc_device == RT_NULL)
- return -RT_ERROR;
- /* update to RTC device. */
- ret = rt_device_control(rtc_device, RT_DEVICE_CTRL_RTC_SET_TIME, ×tamp);
- return ret;
- static time_t rtc_gettime(void)
- static time_t now;
- static struct tm tm;
- now = time(NULL);
- #ifdef _WIN32
- _gmtime32_s(&tm, &now);
- #else
- gmtime_r(&now, &tm);
- #endif
- LOG_D("BJ time:%04d-%02d-%02d %02d:%02d:%02d.%03dn",
- tm.tm_year + 1900, tm.tm_mon + 1,
- tm.tm_mday, tm.tm_hour + 8, tm.tm_min,
- tm.tm_sec, rt_tick_get() % 1000);
- return now;
- static void alarm_time_cb(rt_alarm_t alarm, time_t timestamp)
- LOG_D("alarm_time_cb ok!n");
- static void alarm_hour_cb(rt_alarm_t alarm, time_t timestamp)
- LOG_D("alarm_hour_cb ok!n");
- static void alarm_minute_cb(rt_alarm_t alarm, time_t timestamp)
- LOG_D("alarm_minute_cb ok!n");
- static void alarm_second_cb(rt_alarm_t alarm, time_t timestamp)
- LOG_D("alarm_second_cb ok!n");
- static struct rt_alarm * rtc_alarm_test_create(rt_alarm_callback_t callback, rt_uint32_t flag, struct tm *p_tm)
- struct rt_alarm_setup alarm_setup_test;
- alarm_setup_test.flag = flag;
- alarm_setup_test.wktime.tm_year = p_tm->tm_year;
- alarm_setup_test.wktime.tm_mon = p_tm->tm_mon;
- alarm_setup_test.wktime.tm_mday = p_tm->tm_mday;
- alarm_setup_test.wktime.tm_wday = p_tm->tm_wday;
- alarm_setup_test.wktime.tm_hour = p_tm->tm_hour;
- alarm_setup_test.wktime.tm_min = p_tm->tm_min;
- alarm_setup_test.wktime.tm_sec = p_tm->tm_sec;
- return rt_alarm_create(callback, &alarm_setup_test);
- static void rtc_alarm_time_create(void)
- if (p_alarm_time != RT_NULL)
- return;
- now = time(NULL) + 65;
- #ifdef _WIN32
- #else
- #endif
- p_alarm_time = rtc_alarm_test_create(alarm_time_cb, RT_ALARM_DAILY, &tm);
- static void rtc_alarm_time_start(void)
- rt_alarm_start(p_alarm_time);
- static void rtc_alarm_time_stop(void)
- rt_alarm_stop(p_alarm_time);
- static void rtc_alarm_time_delete(void)
- if (rt_alarm_delete(p_alarm_time) == RT_EOK)
- p_alarm_time = RT_NULL;
- static void rtc_alarm_second_create(void)
- if (p_alarm_sec != RT_NULL)
- return;
- now = time(NULL) + 1;
- #ifdef _WIN32
- #else
- #endif
- p_alarm_sec = rtc_alarm_test_create(alarm_second_cb, RT_ALARM_SECOND, &tm);
- static void rtc_alarm_second_start(void)
- rt_alarm_start(p_alarm_sec);
- static void rtc_alarm_second_stop(void)
- rt_alarm_stop(p_alarm_sec);
- static void rtc_alarm_second_delete(void)
- if (rt_alarm_delete(p_alarm_sec) == RT_EOK)
- p_alarm_sec = RT_NULL;
- static void rtc_alarm_minute_create(void)
- if (p_alarm_min != RT_NULL)
- return;
- now = time(NULL) + 60;
- #ifdef _WIN32
- #else
- #endif
- p_alarm_min = rtc_alarm_test_create(alarm_minute_cb, RT_ALARM_MINUTE, &tm);
- static void rtc_alarm_minute_start(void)
- rt_alarm_start(p_alarm_min);
- static void rtc_alarm_minute_stop(void)
- rt_alarm_stop(p_alarm_min);
- static void rtc_alarm_minute_delete(void)
- if (rt_alarm_delete(p_alarm_min) == RT_EOK)
- p_alarm_min = RT_NULL;
- static void rtc_alarm_hour_create(void)
- if (p_alarm_hour != RT_NULL)
- return;
- now = time(NULL) + 3600;
- #ifdef _WIN32
- #else
- #endif
- p_alarm_hour = rtc_alarm_test_create(alarm_hour_cb, RT_ALARM_HOUR, &tm);
- static void rtc_alarm_hour_start(void)
- rt_alarm_start(p_alarm_hour);
- static void rtc_alarm_hour_stop(void)
- rt_alarm_stop(p_alarm_hour);
- static void rtc_alarm_hour_delete(void)
- if (rt_alarm_delete(p_alarm_hour) == RT_EOK)
- p_alarm_hour = RT_NULL;
- void rtc_alarm_start(int argc, char **argv)
- int index = 0;
- if (argc >= 2)
- index = atoi(argv[1]);
- switch(index)
- case 0:
- rtc_alarm_hour_start();
- break;
- case 1:
- rtc_alarm_minute_start();
- break;
- case 2:
- rtc_alarm_second_start();
- break;
- case 3:
- rtc_alarm_time_start();
- break;
- default:
- break;
- void rtc_alarm_stop(int argc, char **argv)
- int index = 0;
- if (argc >= 2)
- switch(index)
- case 0:
- rtc_alarm_hour_stop();
- break;
- case 1:
- rtc_alarm_minute_stop();
- break;
- case 2:
- rtc_alarm_second_stop();
- break;
- case 3:
- rtc_alarm_time_stop();
- break;
- default:
- break;
- void rtc_alarm_create(int argc, char **argv)
- int index = 0;
- if (argc >= 2)
- switch(index)
- case 0:
- rtc_alarm_hour_create();
- break;
- case 1:
- rtc_alarm_minute_create();
- break;
- case 2:
- rtc_alarm_second_create();
- break;
- case 3:
- rtc_alarm_time_create();
- break;
- default:
- break;
- void rtc_alarm_delete(int argc, char **argv)
- int index = 0;
- if (argc >= 2)
- switch(index)
- case 0:
- rtc_alarm_hour_delete();
- break;
- case 1:
- rtc_alarm_minute_delete();
- break;
- case 2:
- rtc_alarm_second_delete();
- break;
- case 3:
- rtc_alarm_time_delete();
- break;
- default:
- break;
- MSH_CMD_EXPORT(rtc_gettime, rtc get time);
- MSH_CMD_EXPORT(rtc_alarm_create, rtc alarm_create);
- MSH_CMD_EXPORT(rtc_alarm_delete, rtc alarm_delete);
- MSH_CMD_EXPORT(rtc_alarm_start, rtc alarm_start);
- MSH_CMD_EXPORT(rtc_alarm_stop, rtc alarm_stop);
- #endif
总结
RT-Thread RTC alarm组件,配置起来,稍微有点麻烦。
Alarm闹钟功能,使能组件后,还是需要创建闹钟、开启闹钟、停止闹钟、删除闹钟业务代码的配合。
多使用,多总结。
调试记录
drv_rtc.c 代码,供参考
- #include
- #include
- #endif
- #include
- #endif
- #endif
- return;
- struct tm *p_tm;
- return -RT_ERROR;
- return -RT_ERROR;
- return -RT_ERROR;
- #endif
- return RT_EOK;
- #endif
- #else
- #endif
- #else
- #endif
- Error_Handler();
- #endif
- #else
- #endif
- #else
- #else
- #endif
- return -RT_ERROR;
- else
- #endif
- return RT_EOK;
- #endif
- switch (cmd)
- break;
- #endif
- break;
- break;
- else
- break;
- #endif
- return result;
- RT_NULL,
- RT_NULL,
- RT_NULL,
- RT_NULL,
- RT_NULL,
- rt_rtc_control
- #endif
- rt_rtc_init();
- return -RT_ERROR;
- #else
- #endif
- rt_err_t result;
- return result;
- #endif
- return RT_EOK;
- return RT_EOK;
- return RT_EOK;
- #endif
RTC_Alarm 测试代码,供参考
- #include
- #include
- #include
- #define RTC_DEBUG
- #include
- #ifdef RTC_DEBUG
- return -RT_ERROR;
- return ret;
- now = time(NULL);
- #ifdef _WIN32
- #else
- #endif
- return now;
- return;
- #ifdef _WIN32
- #else
- #endif
- return;
- #ifdef _WIN32
- #else
- #endif
- return;
- #ifdef _WIN32
- #else
- #endif
- return;
- #ifdef _WIN32
- #else
- #endif
- int index = 0;
- if (argc >= 2)
- switch(index)
- case 0:
- break;
- case 1:
- break;
- case 2:
- break;
- case 3:
- break;
- default:
- break;
- int index = 0;
- if (argc >= 2)
- switch(index)
- case 0:
- break;
- case 1:
- break;
- case 2:
- break;
- case 3:
- break;
- default:
- break;
- int index = 0;
- if (argc >= 2)
- switch(index)
- case 0:
- break;
- case 1:
- break;
- case 2:
- break;
- case 3:
- break;
- default:
- break;
- int index = 0;
- if (argc >= 2)
- switch(index)
- case 0:
- break;
- case 1:
- break;
- case 2:
- break;
- case 3:
- break;
- default:
- break;
- #endif
总结
多使用,多总结。
调试记录
