乐鑫技术交流
张龙祥
8年用户 1221经验值
擅长:连接器
关链接脚本(ld)的使用中段(section),编译之后user_section_tab段里的内容是空的怎么处理?
使用方式如下:
链接脚本:
Code: Select all
    . = ALIGN(4);
    user_section_tab_local_start = ABSOLUTE(.);
    KEEP (*(SORT(*user_section_tab*)))
    user_section_tab_local_end = ABSOLUTE(.);
a.h:
Code: Select all
#define USER_SECTION_NAME           __attribute__((section("user_section_name_tab")))
#define USER_SECTION                     __attribute__((section("user_section_tab")))
extern void *user_section_tab_local_start;
extern void *user_section_tab_local_end;
const static uint32_t user_section_tab_local_start_addr = (uint32_t)&user_section_tab_local_start;
const static uint32_t user_section_tab_local_end_addr = (uint32_t)&user_section_tab_local_end;
b.h:
Code: Select all
typedef int (*user_func_t)(void *);
struct user_cmd_object {
    user_func_t func;
    const char *breif;
    uint32_t *const param;
#define USER_CMD_EXPORT(name, f, c, p)
    uint32_t _USER_CMD_##name##_param = (uint32_t)p;
    const char _USER_CMD_##name##_name[] SECTION_A_NAME = #c;
    __attribute__((used)) const struct user_cmd_object _USER_CMD_##name##_obj USER_SECTION =
        .func = f,
        .breif = _USER_CMD_##name##_name,
        .param = &_USER_CMD_##name##_param
b.c:
Code: Select all
#include "b.h"
//at+version
static int func_version(void *param)
    printf("%srn", "V1.0.0");
    return 0;
USER_CMD_EXPORT(VERSION, func_version, AT+VERSION, 0);
//at+uid
static int func_uid(void *param)
    printf("%08xrn", u_devid_get());
    return 0;
USER_CMD_EXPORT(UID, func_uid, AT+UID, 0);
编译后得到的map文件:
Code: Select all
                0x000000003c029614                . = ALIGN (0x4)
                0x000000003c029614                user_section_tab_local_start = ABSOLUTE (.)
*(SORT_BY_NAME(*user_section_tab*))
                0x000000003c029614                user_section_tab_local_end = ABSOLUTE (.)
问题是编译之后user_section_tab段里的内容是空的,请问这个问题怎么处理呢?
