我手头有一片nucelo STM32F411RE板子,是透过有源振荡器,osc in ,osc out (空接),然后这个振荡器是由 through STLINK MCO pin of STM32F103 microcontroller. The frequencycannot be changed and is fixed at 8 MHz.
#if defined(STM32F411xE) /*!< Uncomment the following line if you need to clock the STM32F411xE by HSE Bypass
through STLINK MCO pin of STM32F103 microcontroller. The frequency cannot be changed
Hardware configuration needed for Nucleo Board:
?SB54, SB55 OFF
?R35 removed
?SB16, SB50 ON */
/* #define USE_HSE_BYPASS */ //这叙述为何被屏蔽掉
