Matlabwilliam hill官网
12年用户 3经验值
擅长:微处理器/微控制
請問各位神人為什麼我在matlab的 command window 開啟port沒反應??
請問為什麼我在matlab的 command window 開啟port沒反應??
但是在GUI下開啟又正常.....請問各位神人問題在哪邊??
感謝各位神人。
function result = PLCFNC(num,action)
try
    s=serial('COM3','BaudRate',9600,'Parity','even','DataBits',7,'StopBits',1);
    seris=s;
    set(s,'OutputBufferSize',512);
    set(s,'InputBufferSize',1024);
    fopen(s);
catch
    errmsg = lasterr;
    errordlg(['不能打開port: COM3',char(10),'請檢查串口連接或該串口已打開'],'串口打開錯誤');
    rethrow(lasterror);
end
    switch num
        case 0
            if (action == 1)
                tmp = '023730303035034646';
            else
                tmp = '023830303035033030';
            end
        case 1
            if (action == 1)
                tmp = '023730313035033030';
            else
                tmp = '023830313035033031';
            end
        case 2
            if (action == 1)
                tmp = '023730323035033031';
            else
                tmp = '023830323035033032';
            end
        case 3
            if (action == 1)
                tmp = '023730333035033032';
            else
                tmp = '023830333035033033';
            end
        case 4
            if (action == 1)
                tmp = '023730343035033033';
            else
                tmp = '023830343035033034';
            end
        case 5
            if (action == 1)
                tmp = '023730353035033034';
            else
                tmp = '023830353035033035';
            end
        case 6
            if (action == 1)
                tmp = '023730363035033035';
            else
                tmp = '023830363035033036';
            end
        case 7
            if (action == 1)
                tmp = '023730373035033036';
            else
                tmp = '023830373035033037';
            end
        case 10
            if (action == 1)
                tmp = '023730383035033037';
            else
                tmp = '023830383035033038';
            end
        case 11
            if (action == 1)
                tmp = '023730323935033038';
            else
                tmp = '023830393035033039';
            end
        case 12
            if (action == 1)
                tmp = '023730413035033130';
            else
                tmp = '023830413035033131';
            end
        case 13
            if (action == 1)
                tmp = '023730423035033131';
            else
                tmp = '023830423035033132';
            end
        case 14
            if (action == 1)
                tmp = '023730433035033132';
            else
                tmp = '023830433035033133';
            end
        case 15
            if (action == 1)
                tmp = '023730443035033133';
            else
                tmp = '023830443035033134';
            end
        case 16
            if (action == 1)
                tmp = '023730453035033134';
            else
                tmp = '023830453035033135';
            end
        case 17
            if (action == 1)
                tmp = '023730463035033135';
            else
                tmp = '023830463035033136';
            end
    %寫入命令
    data = sscanf(tmp,'%02x')';
    fwrite(s,data,'uint8');
    fclose(s);
    delete(s);
    result = 1;
end
回帖(1)
袁诺
2012-9-21 15:48:16
刚开始学习……加油!
