第五节:数据处理模块
1. 功能描述
处理接收到的信息,因为接收到的信息是按一定规律进行编码的,所以进行解码后,激活数据库线程,保存数据,激活内存刷新数据,更新实时环境信息,判断数据是否越界,若越界则激活设备控制线程进行相应的控制。
2. 数据描述
类型 | | |
| tem_alarm_status[STORAGE_NUM] | |
hum_alarm_status[STORAGE_NUM] | |
ill_alarm_status[STORAGE_NUM] | |
struct env_info_clien_addr | | |
3. 程图
4. 详细说明
在本线程中,进行了大量的工作,如数据的解析,激活数据库线程,以及设置各仓库设备的标志位,并进行检查,同时对接收的数据进行临界检测,主要功能代码如下:
#include "data_global.h"
#include "link_list.h"
#include "sqlite_link_list.h"
struct getEnvMsg
unsigned char sto_no;
unsigned char tem[2];
unsigned char hum[2];
unsigned char x;
unsigned char y;
unsigned char z;
unsigned int ill;
unsigned int battery;
unsigned int adc;
struct getGoodsMsg
unsigned char io;
unsigned char goodsno;
unsigned char goodsnum;
extern linklist linkHead;
extern linklist slinkHead;
extern pthread_mutex_t mutex_linklist;
extern pthread_mutex_t mutex_slinklist;
extern pthread_mutex_t mutex_analysis;
extern pthread_mutex_t mutex_global;
extern pthread_mutex_t mutex_sms;
extern pthread_mutex_t mutex_buzzer;
extern pthread_cond_t cond_analysis;
extern pthread_cond_t cond_sqlite;
extern pthread_cond_t cond_refresh;
extern pthread_cond_t cond_buzzer;
extern pthread_cond_t cond_sms;
char tem_alarm_status[STORAGE_NUM] = {0};
char hum_alarm_status[STORAGE_NUM] = {0};
char ill_alarm_status[STORAGE_NUM] = {0};
char beep_status[STORAGE_NUM] = {0};
extern unsigned char dev_sms_mask;
extern int msgid;
extern int dev_buzzer_mask;
extern struct env_info_clien_addr all_info_RT;
float dota_atof (char unitl)
if (unitl > 100)
return unitl / 1000.0;
else if (unitl > 10)
return unitl / 100.0;
else
return unitl / 10.0;
int dota_atoi (const char * cDecade)
int result = 0;
if (' ' != cDecade[0])
result = (cDecade[0] - 48) * 10;
result += cDecade[1] - 48;
return result;
float dota_adc (unsigned int ratio) {
return ((ratio * 3.6) / 1024);
int storageAllgood (int sto_no)
if ((tem_alarm_status[sto_no] + hum_alarm_status[sto_no] + ill_alarm_status[sto_no]) == 0)
return 0;
return 1;
int checkEnv (int sto_no, struct storage_info *p)
char flag = 0;
static char a8_beep_status = 0;
if (0 == tem_alarm_status[sto_no])
if (p->temperature > p->temperatureMAX)
sendMsgQueue (MSG_LED, MSG_LED_TEM_ON);
sendMsgQueue (MSG_M0, MSG_M0_FAN_ON3 | sto_no << 6);
p->fan_status = 3;
tem_alarm_status[sto_no] = 2;
flag = 1;
else if (p->temperature < p->temperatureMIN)
sendMsgQueue (MSG_M0, MSG_M0_FAN_OFF | sto_no << 6);
p->fan_status = 0;
tem_alarm_status[sto_no] = 1;
flag = 1;
if (flag)
pthread_mutex_lock (&mutex_sms);
dev_sms_mask = SMS_TEM;
pthread_mutex_unlock (&mutex_sms);
pthread_cond_signal (&cond_sms);
flag = 0;
if (beep_status[sto_no] == 0)
beep_status[sto_no] = 1;
sendMsgQueue (MSG_M0, MSG_M0_BEEP_ON | sto_no << 6);
if (a8_beep_status == 0)
a8_beep_status = 1;
sendMsgQueue (MSG_BEEP, MSG_M0_BEEP_ON);
else
if (p->temperature < p->temperatureMAX && p->temperature > p->temperatureMIN)
sendMsgQueue (MSG_LED, MSG_LED_TEM_OFF);
p->fan_status = 0;
tem_alarm_status[sto_no] = 0;
if (!storageAllgood (sto_no))
beep_status[sto_no] = 0;
sendMsgQueue (MSG_M0, MSG_M0_BEEP_OFF | sto_no << 6);
a8_beep_status = 0;
sendMsgQueue (MSG_BEEP, MSG_BEEP_OFF);
if (0 == hum_alarm_status[sto_no])
if (p->humidity > p->humidityMAX)
sendMsgQueue (MSG_LED, MSG_LED_HUM_ON);
p->fan_status = 3;
hum_alarm_status[sto_no] = 2;
flag = 1;
else if (p->humidity < p->humidityMIN)
p->fan_status = 0;
hum_alarm_status[sto_no] = 1;
flag = 1;
if (flag)
dev_sms_mask = SMS_HUM;
flag = 0;
a8_beep_status = 1;
else
if (p->humidity < p->humidityMAX && p->humidity > p->humidityMIN)
sendMsgQueue (MSG_LED, MSG_LED_HUM_OFF);
p->fan_status = 0;
hum_alarm_status[sto_no] = 0;
a8_beep_status = 0;
if (0 == ill_alarm_status[sto_no])
if (p->illumination > p->illuminationMAX)
sendMsgQueue (MSG_LED, MSG_LED_ILL_ON);
sendMsgQueue (MSG_M0, MSG_M0_LED_OFF | sto_no << 6);
p->led_status = 0;
ill_alarm_status[sto_no] = 2;
flag = 1;
else if (p->illumination < p->illuminationMIN)
sendMsgQueue (MSG_M0, MSG_M0_LED_ON | sto_no << 6);
p->led_status = 1;
ill_alarm_status[sto_no] = 1;
flag = 1;
if (flag)
dev_sms_mask = SMS_ILL;
flag = 0;
a8_beep_status = 1;
else if (ill_alarm_status[sto_no])
if (p->illumination < p->illuminationMAX && p->illumination > p->illuminationMIN)
sendMsgQueue (MSG_LED, MSG_LED_ILL_OFF);
p->led_status = 0;
ill_alarm_status[sto_no] = 0;
a8_beep_status = 0;
return 0;
void getEnvPackage (link_datatype *buf)
struct getEnvMsg pack;
memcpy (&pack, buf->text, 20);
int sto_no = pack.sto_no;
pthread_mutex_lock (&mutex_global);
struct storage_info current = all_info_RT.storage_no[sto_no];
pthread_mutex_unlock (&mutex_global);
current.storage_status = 1;
current.x = pack.x;
current.y = pack.y;
current.z = pack.z;
current.temperature = pack.tem[0] + dota_atof (pack.tem[1]);
current.humidity = pack.hum[0] + dota_atof (pack.hum[1]);
current.illumination = pack.ill;
current.battery = dota_adc (pack.battery);
current.adc = dota_adc (pack.adc);
printf ("no = %d tem = %0.2f hum = %0.2f ill = %0.2f battery = %0.2f adc = %0.2f x = %d y %d z = %dn", sto_no,
current.temperature, current.humidity, current.illumination, current.battery, current.adc, current.x, current.y, current.z);
checkEnv (sto_no, ¤t);
all_info_RT.storage_no[sto_no] = current;
pthread_mutex_lock (&mutex_slinklist);
sqlite_InsertLinknode (COLLECT_INSERTER, all_info_RT, sto_no, 0);
pthread_mutex_unlock (&mutex_slinklist);
pthread_cond_signal (&cond_refresh);
pthread_cond_signal (&cond_sqlite);
return ;
void getGoodsPackage (link_datatype *buf)
struct getGoodsMsg pack;
memcpy (&pack, buf->text, 16);
current.goods_info[pack.goodsno].goods_type = pack.goodsno;
current.goods_info[pack.goodsno].goods_count = pack.goodsnum;
printf ("sto_no = %d, io = %c goods_type = %d, goods_num = %dn", sto_no, pack.io, current.goods_info[pack.goodsno].goods_type, current.goods_info[pack.goodsno].goods_count);
if (pack.io == 'I')
sqlite_InsertLinknode (GOODS_ADD, all_info_RT, sto_no, pack.goodsno);//
else if (pack.io == 'O')
sqlite_InsertLinknode (GOODS_REDUCE, all_info_RT, sto_no, pack.goodsno);
return ;
void *pthread_analysis (void *arg)
linklist node;
link_datatype buf;
printf ("pthread_analysis is okn");
while (1)
pthread_mutex_lock (&mutex_analysis);
pthread_cond_wait (&cond_analysis, &mutex_analysis);
pthread_mutex_unlock (&mutex_analysis);
while (1)
pthread_mutex_lock (&mutex_linklist);
if ((node = GetLinknode (linkHead)) == NULL)
pthread_mutex_unlock (&mutex_linklist);
break;
buf = node->data;
free (node);
if ('e' == buf.msg_type)
getEnvPackage (&buf);
else if ('r' == buf.msg_type)
getGoodsPackage (&buf);
return 0;
