EasyEDA-中国人自已的EDA工具
GerryChen
9年用户 188经验值
擅长:电源/新能源 MEMS/传感技术 处理器/DSP
EasyEDA开源硬件——气压传感器模块-T5403(开源硬件)
Description: This is the T5403 breakout board, a fully calibrated barometric pressure sensor with an I2C interface. The T5403 sensor measures the absolute pressure of the air around. This pressure varies with both the weather and altitude. Depending on how you interpret the data, you can monitor changes in the weather, measure altitude, or any other tasks that require an accurate pressure reading.
The T5403 sensor consists of a piezoresistive MEMS pressure sensor element and an ASIC (application specific integrated circuit) with integrated temperature sensor, analog to digital converter ADC, memory and digital circuitry. Each breakout requires a supply voltage of 1.7V to 3.6V with a low current consumption of 790µA max and each pin (GND, VCC, SCL/SCLK, SDA/MOSI, MISO, RST/&SS, SEL, and EOC) broken out.
Features:
Supply Voltage: 1.7-3.6V
Max Current Consumption: 790µA
Pressure Range: 300hPa - 1100hPa
I2C Interface
16 bit ADC
Internal Oscillato
T5403_Barometer_Breakout SCH
T5403_Barometer_Breakout PCB
EasyEDA项目链接:https://easyeda.com/oshw/Barometric_Sensor_Breakout_T5403_Open_hardware-VX5ZvpjBS
EasyEDA链接 :      https://easyeda.com/
