如果您使用WiReSARK进行验证,您会看到由PIC32传输的DHCP包(应该重试)吗?另一个标志是DHCP消息中的单播与广播。交换机是否支持单播DHCP消息?P.S.ItFoad也不适用于静态地址,那么您确实有一个问题,用另一个来改变它,看看问题是否解决了。
以上来自于百度翻译
以下为原文
If you verify with wireshark, do you see the DHCP packets transmitted by PIC32 (there should be retries)?
Another flag that comes to mind is the unicast vs. broadcast in the DHCP message.
Does the switch support unicast DHCP messages?
P.S. I fit doesn't work with static address either, then you really have a problem with that switch.
Change it with another one and see if the problems are solved.
以上来自于百度翻译
以下为原文
