您好,我正在使用SCPI命令远程控制E8527D信号发生器。
我正在尝试使用SCPI创建和应用平坦度校正表,类似于信号发生器用户手册第76-77页(附件)中的步骤。
我找到了为Power Meter配置系统的命令,但我找不到使用Power Meter启动用户平坦度校准的命令。
手动,命令是:幅度 - >用户平坦度 - >执行校准是否有人知道SCPI命令启动此校准?
此致,阿什利
以上来自于谷歌翻译
以下为原文
Hello,
I am using SCPI commands to remotely control an E8527D Signal Generator. I am attemp
ting to create and apply a Flatness Correction table using SCPI, analogously to the procedure in the Signal Generator User's Manual pp 76-77 (attached). I found the commands to configure the system for the Power Meter, but I cannot find the command to initiate the User Flatness Calibration using the Power Meter.
Manually, the command is:
Amplitude --> User Flatness --> Do Cal
Does anyone know the SCPI command to initiate this calibration?
Regards,
Ashley
附件
