单片机学习小组
李永每
7年用户 1445经验值
STM32F407具有哪些特性?
STM32F407具有哪些特性?
回帖(1)
刘波
2022-2-9 15:26:22
设备摘要/特性
  • ARM Cortex-M4 32b MCU+FPU, 210DMIPS
  • up to 1MB Flash/192+4KB RAM
  • Up to 17 timers:
up to twelve 16-bit and two 32-bit timers up to 168 MHz, each with up to 4
IC/OC/PWM or pulse counter and quadrature(正交) (incremental,增量) encoder input
  • 3×12-bit, 2.4 MSPS A/D converters:
up to 24 channels and 7.2 MSPS in triple interleaved mode(三重交替模式)
  • 2×12-bit D/A converters
  • Up to 140 I/O ports with interrupt capability
    – Up to 136 fast I/Os up to 84 MHz
    – Up to 138 5 V-tolerant I/Os
  • 15 communication interfaces :
    – Up to 3 × I2C interfaces
    – Up to 4 USARTs+2 UARTs
    – Up to 3 SPIs (42 Mbits/s)
    – 2 × CAN interfaces (2.0B Active)
    – SDIO/MMC interface
  • Ethernet and the camera interface
描述
  此表引自STMF407X数据手册,2015
Table 2. STM32F405xx and STM32F407xx: features and peripheral counts (continued)
device overview
此处略
引脚排列和引脚说明
FT: 5 V tolerant I/O
Table 7. STM32F40x pin and ball definitions
  查看引脚类型、是否为5v容忍引脚
Table 9. Alternate function mapping(复用功能映射)
  此表记录了复用功能映射,非常重要,共10页
电气特性
参数条件
Unless otherwise specified:
  • all voltages are referenced to VSS.
  • typical data are based on TA = 25 °C, VDD = 3.3 V (for the 1.8 V ≤ VDD ≤ 3.6 V voltage range).
绝对最大额定值
  Exposure to maximum rating conditions for extended periods may affect
device reliability.
Input voltage on 5v tolerant pin:VSS-0.3~VDD+4V
Input voltage on any other pin:VSS-0.3~4V
工作条件
通用工作条件
VDDA=VDD: 1.8-3.6V
VDDA必须与VDD相连
VREF+:1.8-3.6V
VSSA必须与VREF-相连
VSS必须与VSSA相连
VSS=VSSA=VREF-=GND
VBAT: 1.65-3.6V
最大结点温度:125℃
