如下是客户要求,有会的或者有资源可联系我,对公合作。
1、SPICE Model format
---txt file or .lib file
2、SPICE Model content
2.1、SPICE Model of the diode for
2.1.1、The typical I –V curve defined in the datasheet
2.1.2、Each voltage BIN defined in the datasheet
----Min., mid. and max. values of each voltage BIN
2.1.3、With capacity to simulate temperature varia
tions
2.2、Enough data to model the diode behavior completely (current and temperature variations)
2.2.1、Minimum required parameters: IS, N, RS, EG, XTI, TRS1, TRS2
