威廉希尔官方网站 设计william hill官网
史晓明
7年用户 952经验值
[资料]
W50267ASZ6_sstc_12v_gerber的资料分享
描述
固态特斯拉线圈 230V 至 +12V 电源板,带有线性稳压器,为 SSTC 控制板供电。
物料清单
项目 数量 参考值 LibPart 封装
C1 1000u 器件:C_Polarized Capacitor_THT:CP_Radial_D12.5mm_P5.00mm
C2 1000u 器件:C_Polarized Capacitor_THT:CP_Radial_D12.5mm_P5.00mm
C3 10u 器件:C_Polarized Capacitor_THT:CP_Radial_D10.0mm_P3.50mm
C4 100n 器件:C 电容器_THT:C_Rect_L7.0mm_W3.5mm_P5.00mm
C5 100n 器件:C 电容器_THT:C_Rect_L7.0mm_W3.5mm_P5.00mm
C6 10u 器件:C_Polarized Capacitor_THT:CP_Radial_D10.0mm_P3.50mm
D1 1N4001 二极管:1N4001 二极管_THT:D_DO-41_SOD81_P10.16mm_Horizo​​ntal
D2 1N4001 二极管:1N4001 二极管_THT:D_DO-41_SOD81_P10.16mm_Horizo​​ntal
D3 1N4001 二极管:1N4001 二极管_THT:D_DO-41_SOD81_P10.16mm_Horizo​​ntal
D4 1N4001 二极管:1N4001 二极管_THT:D_DO-41_SOD81_P10.16mm_Horizo​​ntal
D5 1N4148 设备:D 二极管_THT:D_DO-35_SOD27_P7.62mm_Horizo​​ntal
D6 1N4148 设备:D 二极管_THT:D_DO-35_SOD27_P7.62mm_Horizo​​ntal
D7 LED 设备:LED LED_THT:LED_D3.0mm
F1 保险丝装置:保险丝保险丝:Fuseholder_Cylinder-5x20mm_Schurter_0031_8201_Horizo​​ntal_Open
F2 保险丝装置:保险丝保险丝:Fuseholder_Cylinder-5x20mm_Schurter_0031_8201_Horizo​​ntal_Open
H1 安装孔机械:安装孔安装孔:安装孔_4.3mm_M4
H2 安装孔机械:安装孔安装孔:安装孔_4.3mm_M4
H3 安装孔机械:安装孔安装孔:安装孔_4.3mm_M4
H4安装孔机械:安装孔安装孔:安装孔_4.3mm_M4
J1 Conn_01x03_Male Connector:Conn_01x03_Male TerminalBlock:TerminalBlock_bornier-3_P5.08mm
J2 Conn_01x02_Male Connector:Conn_01x02_Male TerminalBlock:TerminalBlock_bornier-2_P5.08mm
JP1 Jumper_2_Open Jumper:Jumper_2_Open TestPoint:TestPoint_2pads_Pitch2.54mm_Drill0.8mm
JP2 Jumper_2_Open Jumper:Jumper_2_Open TestPoint:TestPoint_2Pads_Pitch2.54mm_Drill0.8mm
JP3 Jumper_2_Open Jumper:Jumper_2_Open TestPoint:TestPoint_2Pads_Pitch2.54mm_Drill0.8mm
R1 R设备:R电阻器_THT:R_Axial_DIN0207_L6.3mm_D2.5mm_P10.16mm_Horizo​​ntal
U1 BV_EI_382_1194 custom_parts:BV_EI_382_1194 custom_parts:BV EI 382 1994
U2 BV_EI_382_1194 custom_parts:BV_EI_382_1194 custom_parts:BV EI 382 1994
U3 LM7812_TO220 Regulator_Linear:LM7812_TO220 Package_TO_SOT_THT:TO-220-3_Vertical
PCB
