贾埃罗
7年用户 1709经验值
RK3588固件烧录完成后卡住不动了可能是什么问题
  问题描述及复现步骤:请问进入到maskrom模式然后烧录固件:
  sudo upgrade_tool uf ITX-3588J_Android12_HDMI_220830.img
  Program Data in /home/zhang/.config/upgrade_tool
  Loading firmware.。.
  Support Type:RK3588 FW Ver:c.0.00 FW Time:2022-08-30 08:29:28
  Loader ver:1.0b Loader Time:2022-08-29 18:15:38
  Upgrade firmware ok.
  固件烧录完成后,串口打印到如下信息,然后卡住不动了,可能是什么问题?
  DDR Version V1.07 20220412
  LPDDR4X, 2112MHz
  channel[0] BW=16 Col=10 Bk=8 CS0 Row=17 CS=1 Die BW=16 Size=2048MB
  channel[1] BW=16 Col=10 Bk=8 CS0 Row=17 CS=1 Die BW=16 Size=2048MB
  channel[2] BW=16 Col=10 Bk=8 CS0 Row=17 CS=1 Die BW=16 Size=2048MB
  channel[3] BW=16 Col=10 Bk=8 CS0 Row=17 CS=1 Die BW=16 Size=2048MB
  change to F1: 528MHz
  change to F2: 1068MHz
  change to F3: 1560MHz
  change to F0: 2112MHz
  out
  U-Boot SPL board init
  U-Boot SPL 2017.09 (Aug 29 2022 - 18:14:55)
  unknown raw ID phN
  unrecognized JEDEC id bytes: 00, 00, 00
  Trying to boot from MMC2
  Card did not respond to voltage select!
  mmc_init: -95, time 12
  spl: mmc init failed with error: -95
  Trying to boot from MMC1
  Trying fit image at 0x4000 sector
  ## Verified-boot: 0
  ## Checking atf-1 0x00040000 。.. sha256(581130cddd.。.) + OK
  ## Checking uboot 0x00200000 。.. sha256(15714d1d95.。.) + OK
  ## Checking fdt 0x003284b8 。.. sha256(c07f4a4d71.。.) + OK
  ## Checking atf-2 0x000f0000 。.. sha256(6a00298af8.。.) + OK
  ## Checking atf-3 0xff100000 。.. sha256(71c3a5841b.。.) + OK
  ## Checking atf-4 0xff001000 。.. sha256(2301cf73be.。.) + OK
  ## Checking optee 0x08400000 。.. sha256(603cfbd25d.。.) + OK
  Jumping to U-Boot(0x00200000) via ARM Trusted Firmware(0x00040000)
  Total: 129.433 ms
回帖(3)
李伟
2022-9-14 15:10:07
先确认一下你用的是roc-rk3588s-pc的机器,那烧录的是对应固件,你现在烧录ITX-3588J的固件这样是不行的哦
贾埃罗
2022-9-14 15:10:28
已经验证硬件上出了问题. 更换3588J核心板就可以正常工了.
但是在测试hdmi固件和mipi固件时,发现hdmi固件没有什么问题,mipi固件接上hdmi屏幕只有中间一块有显示,两边都是黑色的,并且点击导航栏
旋屏按钮无法旋转过来,这个要怎么修改?
李伟
2022-9-14 15:10:42
这是由于dpi 的问题导致,可以修改如下
--- a/device/rockchip/rk3588/rk3588_firefly_itx_3588j_mipi/rk3588_firefly_itx_3588j_mipi.mk
+++ b/device/rockchip/rk3588/rk3588_firefly_itx_3588j_mipi/rk3588_firefly_itx_3588j_mipi.mk
@@ -44,7 +44,7 @@ PRODUCT_FIREFLY_NAME := MIPI
## add Rockchip properties
-PRODUCT_PROPERTY_OVERRIDES += ro.sf.lcd_density=320
+PRODUCT_PROPERTY_OVERRIDES += ro.sf.lcd_density=160
