当我使用HTTP POST/GET请求时,每次请求耗时一般在100-300ms左右
更改为HTTPS,并加入服务器证书校验后,每次请求耗时需要3s以上
我尝试过下面这几种配置方式,但是耗时变化不大
1、
    esp_tls_cfg_t cfg = {
        .use_global_ca_store = true,
2、
        .cacert_buf = (const unsigned char *) server_root_cert_pem_start,
        .cacert_bytes = server_root_cert_pem_end - server_root_cert_pem_start,
3、
        .crt_bundle_attach = esp_crt_bundle_attach,
然后我跟踪源码运行发现,每次请求耗时主要在esp_mbedtls_handshake内
Then I tracked the source code and ran and found that each request took less than esp_mbedtls_handshake
E (9881) esp-tls-mbedtls: -------start  = 9270ms esp_mbedtls_handshake
I (10691) esp-x509-crt-bundle: Cer
tificate validated
E (15741) esp-tls-mbedtls: -------end =15130ms esp_mbedtls_handshake
这是否是正常的HTTPS请求耗时?还是我的配置出现问题?是否有优化请求耗时的方法呢?
下方是完整的启动、请求日志:
entry 0x40080694
I (27) boot: ESP-IDF v4.4.2-378-g9269a536ac-dirty 2nd stage bootloader
I (27) boot: compile time 22:13:45
I (28) boot: chip revision: 3
I (32) boot_comm: chip revision: 3, min. bootloader chip revision: 0
I (39) boot.esp32: SPI Speed      : 40MHz
I (44) boot.esp32: SPI Mode       : DIO
I (48) boot.esp32: SPI Flash Size : 2MB
I (53) boot: Enabling RNG early entropy source...
I (58) boot: Partition Table:
I (62) boot: ## Label            Usage          Type ST Offset   Length
I (69) boot:  0 nvs              WiFi data        01 02 00009000 00006000
I (77) boot:  1 phy_init         RF data          01 01 0000f000 00001000
I (84) boot:  2 factory          factory app      00 00 00010000 00100000
I (92) boot: End of partition table
I (96) boot_comm: chip revision: 3, min. application chip revision: 0
I (103) esp_image: segment 0: paddr=00010020 vaddr=3f400020 size=28eb8h (167608) map
I (172) esp_image: segment 1: paddr=00038ee0 vaddr=3ffb0000 size=03800h ( 14336) load
I (178) esp_image: segment 2: paddr=0003c6e8 vaddr=40080000 size=03930h ( 14640) load
I (184) esp_image: segment 3: paddr=00040020 vaddr=400d0020 size=88158h (557400) map
I (388) esp_image: segment 4: paddr=000c8180 vaddr=40083930 size=10f64h ( 69476) load
I (417) esp_image: segment 5: paddr=000d90ec vaddr=50000000 size=00010h (    16) load
I (427) boot: Loaded app from partition at offset 0x10000
I (427) boot: Disabling RNG early entropy source...
I (439) cpu_start: Pro cpu up.
I (439) cpu_start: Starting app cpu, entry point is 0x400811a4
0x400811a4: call_start_cpu1 at /home/leo/work/esp/esp-idf/components/esp_system/port/cpu_start.c:148
I (0) cpu_start: App cpu up.
I (456) cpu_start: Pro cpu start user code
I (456) cpu_start: cpu freq: 160000000
I (456) cpu_start: Application information:
I (460) cpu_start: Project name:     https_request
I (466) cpu_start: App version:      1
I (470) cpu_start: Compile time:     Jan 10 2023 22:13:40
I (476) cpu_start: ELF file SHA256:  3ad1424200dff368...
I (482) cpu_start: ESP-IDF:          v4.4.2-378-g9269a536ac-dirty
I (489) heap_init: Initializing. RAM available for dynamic allocation:
I (496) heap_init: At 3FFAE6E0 len 00001920 (6 KiB): DRAM
I (502) heap_init: At 3FFB7790 len 00028870 (162 KiB): DRAM
I (508) heap_init: At 3FFE0440 len 00003AE0 (14 KiB): D/IRAM
I (515) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM
I (521) heap_init: At 40094894 len 0000B76C (45 KiB): IRAM
I (529) spi_flash: detected chip: generic
I (532) spi_flash: flash io: dio
W (536) spi_flash: Detected size(4096k) larger than the size in the binary image header(2048k). Using the size in the binary image header.
I (550) cpu_start: Starting scheduler on PRO CPU.
I (0) cpu_start: Starting scheduler on APP CPU.
I (671) wifi:wifi driver task: 3ffc01f8, prio:23, stack:6656, core=0
I (671) system_api: Base MAC address is not set
I (671) system_api: read default base MAC address from EFUSE
I (691) wifi:wifi firmware version: f1d33cc
I (691) wifi:wifi certification version: v7.0
I (691) wifi:config NVS flash: enabled
I (691) wifi:config nano formating: disabled
I (701) wifi:Init data frame dynamic rx buffer num: 32
I (701) wifi:Init management frame dynamic rx buffer num: 32
I (711) wifi:Init management short buffer num: 32
I (711) wifi:Init dynamic tx buffer num: 32
I (721) wifi:Init static rx buffer size: 1600
I (721) wifi:Init static rx buffer num: 10
I (731) wifi:Init dynamic rx buffer num: 32
I (731) wifi_init: rx ba win: 6
I (731) wifi_init: tcpip mbox: 32
I (741) wifi_init: udp mbox: 6
I (741) wifi_init: tcp mbox: 6
I (741) wifi_init: tcp tx win: 5744
I (751) wifi_init: tcp rx win: 5744
I (751) wifi_init: tcp mss: 1440
I (761) wifi_init: WiFi IRAM OP enabled
I (761) wifi_init: WiFi RX IRAM OP enabled
I (771) example_connect: Connecting to midea_ceshi_002...
I (771) phy_init: phy_version 4670,719f9f6,Feb 18 2021,17:07:07
W (781) phy_init: failed to load RF calibration data (0xffffffff), falling back to full calibration
I (1051) wifi:mode : sta (b8:d6:1a:33:d0:e4)
I (1051) wifi:enable tsf
I (1061) example_connect: Waiting for IP(s)
I (3471) wifi<8,0>, old:<1,0>, ap:<255,255>, sta:<8,0>, prof:1
I (4211) wifi:state: init -> auth (b0)
I (4221) wifi:state: auth -> assoc (0)
I (4221) wifi:state: assoc -> run (10)
W (4231) wifi:idx:0 (ifx:0, 34:97:f6:b6:22:a0), tid:0, ssn:0, winSize:64
I (4251) wifi:connected with midea_ceshi_002, aid = 7, channel 8, BW20, bssid = 34:97:f6:b6:22:a0
I (4251) wifi:security: WPA2-PSK, phy: bgn, rssi: -42
I (4251) wifi:pm start, type: 1
I (4331) wifi:AP's beacon interval = 102400 us, DTIM period = 3
I (5661) example_connect: Got IPv6 event: Interface "example_connect: sta" address: fe80:0000:0000:0000:bad6:1aff:fe33:d0e4, type: ESP_IP6_ADDR_IS_LINK_LOCAL
I (9161) esp_netif_handlers: example_connect: sta ip: 192.168.3.137, mask: 255.255.255.0, gw: 192.168.3.1
I (9161) example_connect: Got IPv4 event: Interface "example_connect: sta" address: 192.168.3.137
I (9171) example_connect: Connected to example_connect: sta
I (9171) example_connect: - IPv4 address: 192.168.3.137
I (9181) example_connect: - IPv6 address: fe80:0000:0000:0000:bad6:1aff:fe33:d0e4, type: ESP_IP6_ADDR_IS_LINK_LOCAL
I (9191) example: Start https_request example
I (9201) example: https_request using crt bundle
I (10691) esp-x509-crt-bundle: Certificate validated
I (15741) example: Connection established...
I (15751) example: 106 bytes written
I (15751) example: Reading HTTP response...
HTTP/1.1 200 OK
Content-Length: 2091
Access-Control-Allow-Origin: *
Connection: close
Content-Type: application/json
Date: Wed, 11 Jan 2023 06:15:16 GMT
Strict-Transport-Security: max-age=631138519; includeSubdomains; preload
I (42881) example: https_request using global ca_store
E (44281) esp-tls-mbedtls: -------start  = 43670ms esp_mbedtls_handshake
E (47381) esp-tls-mbedtls: -------end =46770ms esp_mbedtls_handshake
I (47391) example: Connection established...
I (47401) example: 106 bytes written
I (47401) example: Reading HTTP response...
HTTP/1.1 200 OK
Connection: close
Date: Wed, 11 Jan 2023 06:15:48 GMT
Top
以下内容为评论
ESP_YJM        Posts: 300                Joined: Fri Feb 26, 2021 10:30 am
Re: ESP32-S3 HTTPS esp_mbedtls_handshake握手平均耗时3s以上
        Postby
ESP_YJM » Wed Jan 11, 2023 11:12 am
        能否提供下你的 sdkconfig 以及打开 mbedtls debug 查看下 mbedtls 握手所使用的套件。
Top
        kangzy4        Posts: 6                Joined: Wed Jan 11, 2023 7:18 am
        Postby
kangzy4 » Sun Jan 15, 2023 12:46 am
        好的,这里提供下配置和日志信息如下:
下方是sdkconfig与TLS相关的配置
# ESP-TLS
CONFIG_ESP_TLS_USING_MBEDTLS=y
CONFIG_ESP_TLS_USE_DS_PERIPHERAL=y
# CONFIG_ESP_TLS_CLIENT_SESSION_TICKETS is not set
# CONFIG_ESP_TLS_SERVER is not set
# CONFIG_ESP_TLS_PSK_VERIFICATION is not set
CONFIG_ESP_TLS_INSECURE=y
CONFIG_ESP_TLS_SKIP_SERVER_CERT_VERIFY=y
# end of ESP-TLS
# mbedTLS
CONFIG_MBEDTLS_INTERNAL_MEM_ALLOC=y
# CONFIG_MBEDTLS_EXTERNAL_MEM_ALLOC is not set
# CONFIG_MBEDTLS_DEFAULT_MEM_ALLOC is not set
# CONFIG_MBEDTLS_CUSTOM_MEM_ALLOC is not set
CONFIG_MBEDTLS_ASYMMETRIC_CONTENT_LEN=y
CONFIG_MBEDTLS_SSL_IN_CONTENT_LEN=16384
CONFIG_MBEDTLS_SSL_OUT_CONTENT_LEN=4096
# CONFIG_MBEDTLS_DYNAMIC_BUFFER is not set
CONFIG_MBEDTLS_DEBUG=y
# CONFIG_MBEDTLS_DEBUG_LEVEL_WARN is not set
# CONFIG_MBEDTLS_DEBUG_LEVEL_INFO is not set
# CONFIG_MBEDTLS_DEBUG_LEVEL_DEBUG is not set
CONFIG_MBEDTLS_DEBUG_LEVEL_VERBOSE=y
CONFIG_MBEDTLS_DEBUG_LEVEL=4
# mbedTLS v2.28.x related
# CONFIG_MBEDTLS_SSL_VARIABLE_BUFFER_LENGTH is not set
# CONFIG_MBEDTLS_X509_TRUSTED_CERT_CALLBACK is not set
# CONFIG_MBEDTLS_SSL_CONTEXT_SERIALIZATION is not set
CONFIG_MBEDTLS_SSL_KEEP_PEER_CERTIFICATE=y
# end of mbedTLS v2.28.x related
# Certificate Bundle
CONFIG_MBEDTLS_CERTIFICATE_BUNDLE=y
CONFIG_MBEDTLS_CERTIFICATE_BUNDLE_DEFAULT_FULL=y
# CONFIG_MBEDTLS_CERTIFICATE_BUNDLE_DEFAULT_CMN is not set
# CONFIG_MBEDTLS_CERTIFICATE_BUNDLE_DEFAULT_NONE is not set
# CONFIG_MBEDTLS_CUSTOM_CERTIFICATE_BUNDLE is not set
CONFIG_MBEDTLS_CERTIFICATE_BUNDLE_MAX_CERTS=200
# end of Certificate Bundle
# CONFIG_MBEDTLS_ECP_RESTARTABLE is not set
# CONFIG_MBEDTLS_CMAC_C is not set
CONFIG_MBEDTLS_HARDWARE_AES=y
CONFIG_MBEDTLS_AES_USE_INTERRUPT=y
CONFIG_MBEDTLS_HARDWARE_MPI=y
CONFIG_MBEDTLS_HARDWARE_SHA=y
CONFIG_MBEDTLS_ROM_MD5=y
# CONFIG_MBEDTLS_ATCA_HW_ECDSA_SIGN is not set
# CONFIG_MBEDTLS_ATCA_HW_ECDSA_VERIFY is not set
CONFIG_MBEDTLS_HAVE_TIME=y
# CONFIG_MBEDTLS_HAVE_TIME_DATE is not set
CONFIG_MBEDTLS_ECDSA_DETERMINISTIC=y
CONFIG_MBEDTLS_SHA512_C=y
CONFIG_MBEDTLS_TLS_SERVER_AND_CLIENT=y
# CONFIG_MBEDTLS_TLS_SERVER_ONLY is not set
# CONFIG_MBEDTLS_TLS_CLIENT_ONLY is not set
# CONFIG_MBEDTLS_TLS_DISABLED is not set
CONFIG_MBEDTLS_TLS_SERVER=y
CONFIG_MBEDTLS_TLS_CLIENT=y
CONFIG_MBEDTLS_TLS_ENABLED=y
# TLS Key Exchange Methods
# CONFIG_MBEDTLS_PSK_MODES is not set
CONFIG_MBEDTLS_KEY_EXCHANGE_RSA=y
CONFIG_MBEDTLS_KEY_EXCHANGE_DHE_RSA=y
CONFIG_MBEDTLS_KEY_EXCHANGE_ELLIPTIC_CURVE=y
CONFIG_MBEDTLS_KEY_EXCHANGE_ECDHE_RSA=y
CONFIG_MBEDTLS_KEY_EXCHANGE_ECDHE_ECDSA=y
CONFIG_MBEDTLS_KEY_EXCHANGE_ECDH_ECDSA=y
CONFIG_MBEDTLS_KEY_EXCHANGE_ECDH_RSA=y
# end of TLS Key Exchange Methods
CONFIG_MBEDTLS_SSL_RENEGOTIATION=y
# CONFIG_MBEDTLS_SSL_PROTO_SSL3 is not set
CONFIG_MBEDTLS_SSL_PROTO_TLS1=y
CONFIG_MBEDTLS_SSL_PROTO_TLS1_1=y
CONFIG_MBEDTLS_SSL_PROTO_TLS1_2=y
# CONFIG_MBEDTLS_SSL_PROTO_GMTSSL1_1 is not set
# CONFIG_MBEDTLS_SSL_PROTO_DTLS is not set
CONFIG_MBEDTLS_SSL_ALPN=y
CONFIG_MBEDTLS_CLIENT_SSL_SESSION_TICKETS=y
CONFIG_MBEDTLS_X509_CHECK_KEY_USAGE=y
CONFIG_MBEDTLS_X509_CHECK_EXTENDED_KEY_USAGE=y
CONFIG_MBEDTLS_SERVER_SSL_SESSION_TICKETS=y
# Symmetric Ciphers
CONFIG_MBEDTLS_AES_C=y
# CONFIG_MBEDTLS_CAMELLIA_C is not set
# CONFIG_MBEDTLS_DES_C is not set
CONFIG_MBEDTLS_RC4_DISABLED=y
# CONFIG_MBEDTLS_RC4_ENABLED_NO_DEFAULT is not set
# CONFIG_MBEDTLS_RC4_ENABLED is not set
# CONFIG_MBEDTLS_BLOWFISH_C is not set
# CONFIG_MBEDTLS_XTEA_C is not set
CONFIG_MBEDTLS_CCM_C=y
CONFIG_MBEDTLS_GCM_C=y
# CONFIG_MBEDTLS_NIST_KW_C is not set
# end of Symmetric Ciphers
# CONFIG_MBEDTLS_RIPEMD160_C is not set
# Certificates
CONFIG_MBEDTLS_PEM_PARSE_C=y
CONFIG_MBEDTLS_PEM_WRITE_C=y
CONFIG_MBEDTLS_X509_CRL_PARSE_C=y
CONFIG_MBEDTLS_X509_CSR_PARSE_C=y
# end of Certificates
CONFIG_MBEDTLS_ECP_C=y
CONFIG_MBEDTLS_ECDH_C=y
CONFIG_MBEDTLS_ECDSA_C=y
# CONFIG_MBEDTLS_ECJPAKE_C is not set
CONFIG_MBEDTLS_ECP_DP_SECP192R1_ENABLED=y
CONFIG_MBEDTLS_ECP_DP_SECP224R1_ENABLED=y
CONFIG_MBEDTLS_ECP_DP_SECP256R1_ENABLED=y
CONFIG_MBEDTLS_ECP_DP_SECP384R1_ENABLED=y
CONFIG_MBEDTLS_ECP_DP_SECP521R1_ENABLED=y
CONFIG_MBEDTLS_ECP_DP_SECP192K1_ENABLED=y
CONFIG_MBEDTLS_ECP_DP_SECP224K1_ENABLED=y
CONFIG_MBEDTLS_ECP_DP_SECP256K1_ENABLED=y
CONFIG_MBEDTLS_ECP_DP_BP256R1_ENABLED=y
CONFIG_MBEDTLS_ECP_DP_BP384R1_ENABLED=y
CONFIG_MBEDTLS_ECP_DP_BP512R1_ENABLED=y
CONFIG_MBEDTLS_ECP_DP_CURVE25519_ENABLED=y
CONFIG_MBEDTLS_ECP_NIST_OPTIM=y
# CONFIG_MBEDTLS_POLY1305_C is not set
# CONFIG_MBEDTLS_CHACHA20_C is not set
# CONFIG_MBEDTLS_HKDF_C is not set
# CONFIG_MBEDTLS_THREADING_C is not set
# CONFIG_MBEDTLS_LARGE_KEY_SOFTWARE_MPI is not set
# CONFIG_MBEDTLS_SECURITY_RISKS is not set
# end of mbedTLS
下面是开启Mbedtls后的日志
I (31829) ms_camera: picture: 1280 x 720 22111byte
I (31834) ms_http_client: picture size = 22111
I (31846) ms_http_client: http_get_task 2
I (31851) ms_http_client: http_loader_len = 22553
I (31855) ms_http_client: HTTP POST:30606
E (31860) TRANSPORT_BASE: -------send time test=30611ms  ssl_connect
E (31907) esp-tls: -------send time test3=30658ms  tcp_connect
E (31907) esp-tls-mbedtls: -------send time2=30658ms esp_mbedtls_handshake
I (31910) mbedtls: ssl_tls.c:5905 => handshake
I (31922) mbedtls: ssl_cli.c:4483 client state: 0
I (31927) mbedtls: ssl_msg.c:2102 => flush output
I (31933) mbedtls: ssl_msg.c:2114 <= flush output
I (31945) mbedtls: ssl_cli.c:4483 client state: 1
I (31950) mbedtls: ssl_msg.c:2102 => flush output
I (31956) mbedtls: ssl_msg.c:2114 <= flush output
I (31961) mbedtls: ssl_cli.c:999 => write client hello
I (31970) mbedtls: ssl_msg.c:2542 => write handshake message
I (31974) mbedtls: ssl_msg.c:2701 => write record
I (31981) mbedtls: ssl_msg.c:2102 => flush output
I (31985) mbedtls: ssl_msg.c:2122 message length: 244, out_left: 244
I (31994) mbedtls: ssl_msg.c:2127 ssl->f_send() returned 244 (-0xffffff0c)
I (32000) mbedtls: ssl_msg.c:2155 <= flush output
I (32006) mbedtls: ssl_msg.c:2870 <= write record
I (32011) mbedtls: ssl_msg.c:2678 <= write handshake message
I (32018) mbedtls: ssl_cli.c:1467 <= write client hello
I (32030) mbedtls: ssl_cli.c:4483 client state: 2
I (32036) mbedtls: ssl_msg.c:2102 => flush output
I (32041) mbedtls: ssl_msg.c:2114 <= flush output
I (32047) mbedtls: ssl_cli.c:2082 => parse server hello
I (32053) mbedtls: ssl_msg.c:3941 => read record
I (32058) mbedtls: ssl_msg.c:1886 => fetch input
I (32064) mbedtls: ssl_msg.c:2043 in_left: 0, nb_want: 5
I (32070) mbedtls: ssl_msg.c:2068 in_left: 0, nb_want: 5
I (32076) mbedtls: ssl_msg.c:2069 ssl->f_recv(_timeout)() returned 5 (-0xfffffffb)
I (32085) mbedtls: ssl_msg.c:2089 <= fetch input
I (32090) mbedtls: ssl_msg.c:1886 => fetch input
I (32096) mbedtls: ssl_msg.c:2043 in_left: 5, nb_want: 70
I (32102) mbedtls: ssl_msg.c:2068 in_left: 5, nb_want: 70
I (32108) mbedtls: ssl_msg.c:2069 ssl->f_recv(_timeout)() returned 65 (-0xffffffbf)
I (32117) mbedtls: ssl_msg.c:2089 <= fetch input
I (32123) mbedtls: ssl_msg.c:4015 <= read record
I (32128) mbedtls: ssl_cli.c:2385 server hello, total extension length: 21
I (32136) mbedtls: ssl_cli.c:2627 <= parse server hello
I (32148) mbedtls: ssl_cli.c:4483 client state: 3
I (32153) mbedtls: ssl_msg.c:2102 => flush output
I (32159) mbedtls: ssl_msg.c:2114 <= flush output
I (32164) mbedtls: ssl_tls.c:2878 => parse certificate
I (32170) mbedtls: ssl_msg.c:3941 => read record
I (32176) mbedtls: ssl_msg.c:1886 => fetch input
I (32181) mbedtls: ssl_msg.c:2043 in_left: 0, nb_want: 5
I (32188) mbedtls: ssl_msg.c:2068 in_left: 0, nb_want: 5
I (32194) mbedtls: ssl_msg.c:2069 ssl->f_recv(_timeout)() returned 5 (-0xfffffffb)
I (32202) mbedtls: ssl_msg.c:2089 <= fetch input
I (32208) mbedtls: ssl_msg.c:1886 => fetch input
I (32213) mbedtls: ssl_msg.c:2043 in_left: 5, nb_want: 2738
I (32221) mbedtls: ssl_msg.c:2068 in_left: 5, nb_want: 2738
I (32226) mbedtls: ssl_msg.c:2069 ssl->f_recv(_timeout)() returned 2733 (-0xfffff553)
I (32235) mbedtls: ssl_msg.c:2089 <= fetch input
I (32259) mbedtls: ssl_msg.c:4015 <= read record
I (32266) mbedtls: ssl_tls.c:2989 <= parse certificate
I (32268) mbedtls: ssl_cli.c:4483 client state: 4
I (32273) mbedtls: ssl_msg.c:2102 => flush output
I (32279) mbedtls: ssl_msg.c:2114 <= flush output
I (32284) mbedtls: ssl_cli.c:3094 => parse server key exchange
I (32291) mbedtls: ssl_msg.c:3941 => read record
I (32297) mbedtls: ssl_msg.c:1886 => fetch input
I (32302) mbedtls: ssl_msg.c:2043 in_left: 0, nb_want: 5
I (32309) mbedtls: ssl_msg.c:2068 in_left: 0, nb_want: 5
I (32315) mbedtls: ssl_msg.c:2069 ssl->f_recv(_timeout)() returned 5 (-0xfffffffb)
I (32323) mbedtls: ssl_msg.c:2089 <= fetch input
I (32329) mbedtls: ssl_msg.c:1886 => fetch input
I (32334) mbedtls: ssl_msg.c:2043 in_left: 5, nb_want: 305
I (32341) mbedtls: ssl_msg.c:2068 in_left: 5, nb_want: 305
I (32347) mbedtls: ssl_msg.c:2069 ssl->f_recv(_timeout)() returned 300 (-0xfffffed4)
I (32355) mbedtls: ssl_msg.c:2089 <= fetch input
I (32363) mbedtls: ssl_msg.c:4015 <= read record
I (32369) mbedtls: ssl_cli.c:2699 ECDH curve: x25519
I (32372) mbedtls: ssl_cli.c:3018 Server used SignatureAlgorithm 1
I (32379) mbedtls: ssl_cli.c:3020 Server used HashAlgorithm 4
I (32407) mbedtls: ssl_cli.c:3487 <= parse server key exchange
I (32410) mbedtls: ssl_cli.c:4483 client state: 5
I (32415) mbedtls: ssl_msg.c:2102 => flush output
I (32421) mbedtls: ssl_msg.c:2114 <= flush output
I (32427) mbedtls: ssl_cli.c:3522 => parse certificate request
I (32433) mbedtls: ssl_msg.c:3941 => read record
I (32439) mbedtls: ssl_msg.c:1886 => fetch input
I (32444) mbedtls: ssl_msg.c:2043 in_left: 0, nb_want: 5
I (32451) mbedtls: ssl_msg.c:2068 in_left: 0, nb_want: 5
I (32457) mbedtls: ssl_msg.c:2069 ssl->f_recv(_timeout)() returned 5 (-0xfffffffb)
I (32465) mbedtls: ssl_msg.c:2089 <= fetch input
I (32471) mbedtls: ssl_msg.c:1886 => fetch input
I (32476) mbedtls: ssl_msg.c:2043 in_left: 5, nb_want: 9
I (32482) mbedtls: ssl_msg.c:2068 in_left: 5, nb_want: 9
I (32488) mbedtls: ssl_msg.c:2069 ssl->f_recv(_timeout)() returned 4 (-0xfffffffc)
I (32497) mbedtls: ssl_msg.c:2089 <= fetch input
I (32502) mbedtls: ssl_msg.c:4015 <= read record
I (32508) mbedtls: ssl_cli.c:3678 <= parse certificate request
I (32521) mbedtls: ssl_cli.c:4483 client state: 6
I (32526) mbedtls: ssl_msg.c:2102 => flush output
I (32532) mbedtls: ssl_msg.c:2114 <= flush output
I (32537) mbedtls: ssl_cli.c:3689 => parse server hello done
I (32544) mbedtls: ssl_msg.c:3941 => read record
I (32549) mbedtls: ssl_msg.c:4011 reuse previously read message
I (32556) mbedtls: ssl_msg.c:4015 <= read record
I (32562) mbedtls: ssl_cli.c:3719 <= parse server hello done
I (32575) mbedtls: ssl_cli.c:4483 client state: 7
I (32580) mbedtls: ssl_msg.c:2102 => flush output
I (32586) mbedtls: ssl_msg.c:2114 <= flush output
I (32591) mbedtls: ssl_tls.c:2229 => write certificate
I (32597) mbedtls: ssl_tls.c:2243 <= skip write certificate
I (32610) mbedtls: ssl_cli.c:4483 client state: 8
I (32616) mbedtls: ssl_msg.c:2102 => flush output
I (32621) mbedtls: ssl_msg.c:2114 <= flush output
I (32627) mbedtls: ssl_cli.c:3734 => write client key exchange
I (33112) mbedtls: ssl_msg.c:2542 => write handshake message
I (33113) mbedtls: ssl_msg.c:2701 => write record
I (33114) mbedtls: ssl_msg.c:2102 => flush output
I (33119) mbedtls: ssl_msg.c:2122 message length: 42, out_left: 42
I (33127) mbedtls: ssl_msg.c:2127 ssl->f_send() returned 42 (-0xffffffd6)
I (33134) mbedtls: ssl_msg.c:2155 <= flush output
I (33139) mbedtls: ssl_msg.c:2870 <= write record
I (33145) mbedtls: ssl_msg.c:2678 <= write handshake message
I (33151) mbedtls: ssl_cli.c:4151 <= write client key exchange
I (33165) mbedtls: ssl_cli.c:4483 client state: 9
I (33170) mbedtls: ssl_msg.c:2102 => flush output
I (33175) mbedtls: ssl_msg.c:2114 <= flush output
I (33181) mbedtls: ssl_cli.c:4196 => write certificate verify
I (33188) mbedtls: ssl_tls.c:1728 => derive keys
I (33193) mbedtls: ssl_tls.c:1930 => calc verify sha256
I (33200) mbedtls: ssl_tls.c:1938 <= calc verify
I (33212) mbedtls: ssl_tls.c:1807 <= derive keys
I (33213) mbedtls: ssl_cli.c:4221 <= skip write certificate verify
I (33224) mbedtls: ssl_cli.c:4483 client state: 10
I (33229) mbedtls: ssl_msg.c:2102 => flush output
I (33235) mbedtls: ssl_msg.c:2114 <= flush output
I (33240) mbedtls: ssl_msg.c:5012 => write change cipher spec
I (33247) mbedtls: ssl_msg.c:2542 => write handshake message
I (33253) mbedtls: ssl_msg.c:2701 => write record
I (33259) mbedtls: ssl_msg.c:2102 => flush output
I (33265) mbedtls: ssl_msg.c:2122 message length: 6, out_left: 6
I (33272) mbedtls: ssl_msg.c:2127 ssl->f_send() returned 6 (-0xfffffffa)
I (33279) mbedtls: ssl_msg.c:2155 <= flush output
I (33285) mbedtls: ssl_msg.c:2870 <= write record
I (33290) mbedtls: ssl_msg.c:2678 <= write handshake message
I (33297) mbedtls: ssl_msg.c:5026 <= write change cipher spec
I (33310) mbedtls: ssl_cli.c:4483 client state: 11
I (33315) mbedtls: ssl_msg.c:2102 => flush output
I (33321) mbedtls: ssl_msg.c:2114 <= flush output
I (33327) mbedtls: ssl_tls.c:3533 => write finished
I (33332) mbedtls: ssl_tls.c:3323 => calc  finished tls sha256
I (33340) mbedtls: ssl_tls.c:3349 <= calc  finished
I (33345) mbedtls: ssl_msg.c:2542 => write handshake message
I (33351) mbedtls: ssl_msg.c:2701 => write record
I (33357) mbedtls: ssl_msg.c:632 => encrypt buf
I (33363) mbedtls: ssl_msg.c:1120 <= encrypt buf
I (33368) mbedtls: ssl_msg.c:2102 => flush output
I (33373) mbedtls: ssl_msg.c:2122 message length: 45, out_left: 45
I (33381) mbedtls: ssl_msg.c:2127 ssl->f_send() returned 45 (-0xffffffd3)
I (33388) mbedtls: ssl_msg.c:2155 <= flush output
I (33393) mbedtls: ssl_msg.c:2870 <= write record
I (33399) mbedtls: ssl_msg.c:2678 <= write handshake message
I (33405) mbedtls: ssl_tls.c:3642 <= write finished
I (33418) mbedtls: ssl_cli.c:4483 client state: 12
I (33423) mbedtls: ssl_msg.c:2102 => flush output
I (33429) mbedtls: ssl_msg.c:2114 <= flush output
I (33435) mbedtls: ssl_cli.c:4365 => parse new session ticket
I (33441) mbedtls: ssl_msg.c:3941 => read record
I (33446) mbedtls: ssl_msg.c:1886 => fetch input
I (33452) mbedtls: ssl_msg.c:2043 in_left: 0, nb_want: 5
I (33479) mbedtls: ssl_msg.c:2068 in_left: 0, nb_want: 5
I (33480) mbedtls: ssl_msg.c:2069 ssl->f_recv(_timeout)() returned 5 (-0xfffffffb)
I (33483) mbedtls: ssl_msg.c:2089 <= fetch input
I (33489) mbedtls: ssl_msg.c:1886 => fetch input
I (33494) mbedtls: ssl_msg.c:2043 in_left: 5, nb_want: 191
I (33501) mbedtls: ssl_msg.c:2068 in_left: 5, nb_want: 191
I (33507) mbedtls: ssl_msg.c:2069 ssl->f_recv(_timeout)() returned 186 (-0xffffff46)
I (33516) mbedtls: ssl_msg.c:2089 <= fetch input
I (33523) mbedtls: ssl_msg.c:4015 <= read record
I (33527) mbedtls: ssl_cli.c:4467 <= parse new session ticket
I (33540) mbedtls: ssl_cli.c:4483 client state: 12
I (33545) mbedtls: ssl_msg.c:2102 => flush output
I (33551) mbedtls: ssl_msg.c:2114 <= flush output
I (33556) mbedtls: ssl_msg.c:5035 => parse change cipher spec
I (33563) mbedtls: ssl_msg.c:3941 => read record
I (33568) mbedtls: ssl_msg.c:1886 => fetch input
I (33574) mbedtls: ssl_msg.c:2043 in_left: 0, nb_want: 5
I (33580) mbedtls: ssl_msg.c:2068 in_left: 0, nb_want: 5
I (33586) mbedtls: ssl_msg.c:2069 ssl->f_recv(_timeout)() returned 5 (-0xfffffffb)
I (33595) mbedtls: ssl_msg.c:2089 <= fetch input
I (33600) mbedtls: ssl_msg.c:1886 => fetch input
I (33606) mbedtls: ssl_msg.c:2043 in_left: 5, nb_want: 6
I (33612) mbedtls: ssl_msg.c:2068 in_left: 5, nb_want: 6
I (33618) mbedtls: ssl_msg.c:2069 ssl->f_recv(_timeout)() returned 1 (-0xffffffff)
I (33626) mbedtls: ssl_msg.c:2089 <= fetch input
I (33632) mbedtls: ssl_msg.c:4015 <= read record
I (33637) mbedtls: ssl_msg.c:5099 <= parse change cipher spec
I (33651) mbedtls: ssl_cli.c:4483 client state: 13
I (33656) mbedtls: ssl_msg.c:2102 => flush output
I (33662) mbedtls: ssl_msg.c:2114 <= flush output
I (33667) mbedtls: ssl_tls.c:3659 => parse finished
I (33673) mbedtls: ssl_tls.c:3323 => calc  finished tls sha256
I (33681) mbedtls: ssl_tls.c:3349 <= calc  finished
I (33685) mbedtls: ssl_msg.c:3941 => read record
I (33691) mbedtls: ssl_msg.c:1886 => fetch input
I (33696) mbedtls: ssl_msg.c:2043 in_left: 0, nb_want: 5
I (33703) mbedtls: ssl_msg.c:2068 in_left: 0, nb_want: 5
I (33709) mbedtls: ssl_msg.c:2069 ssl->f_recv(_timeout)() returned 5 (-0xfffffffb)
I (33717) mbedtls: ssl_msg.c:2089 <= fetch input
I (33723) mbedtls: ssl_msg.c:1886 => fetch input
I (33728) mbedtls: ssl_msg.c:2043 in_left: 5, nb_want: 45
I (33734) mbedtls: ssl_msg.c:2068 in_left: 5, nb_want: 45
I (33740) mbedtls: ssl_msg.c:2069 ssl->f_recv(_timeout)() returned 40 (-0xffffffd8)
I (33749) mbedtls: ssl_msg.c:2089 <= fetch input
I (33755) mbedtls: ssl_msg.c:1144 => decrypt buf
I (33761) mbedtls: ssl_msg.c:1741 <= decrypt buf
I (33766) mbedtls: ssl_msg.c:4015 <= read record
I (33771) mbedtls: ssl_tls.c:3730 <= parse finished
I (33783) mbedtls: ssl_cli.c:4483 client state: 14
I (33789) mbedtls: ssl_msg.c:2102 => flush output
I (33794) mbedtls: ssl_msg.c:2114 <= flush output
I (33800) mbedtls: ssl_cli.c:4594 handshake: done
I (33812) mbedtls: ssl_cli.c:4483 client state: 15
I (33817) mbedtls: ssl_msg.c:2102 => flush output
I (33823) mbedtls: ssl_msg.c:2114 <= flush output
I (33841) mbedtls: ssl_tls.c:5920 <= handshake
E (33846) esp-tls-mbedtls: -------send time3=32597ms esp_mbedtls_handshake
I (33855) mbedtls: ssl_msg.c:5820 => write
I (33859) mbedtls: ssl_msg.c:2701 => write record
I (33864) mbedtls: ssl_msg.c:632 => encrypt buf
I (33873) mbedtls: ssl_msg.c:1120 <= encrypt buf
I (33877) mbedtls: ssl_msg.c:2102 => flush output
I (33881) mbedtls: ssl_msg.c:2122 message length: 238, out_left: 238
I (33889) mbedtls: ssl_msg.c:2127 ssl->f_send() returned 238 (-0xffffff12)
I (33896) mbedtls: ssl_msg.c:2155 <= flush output
I (33901) mbedtls: ssl_msg.c:2870 <= write record
I (33907) mbedtls: ssl_msg.c:5848 <= write
I (33913) mbedtls: ssl_msg.c:5820 => write
I (33917) mbedtls: ssl_msg.c:2701 => write record
I (33922) mbedtls: ssl_msg.c:632 => encrypt buf
I (33970) mbedtls: ssl_msg.c:1120 <= encrypt buf
I (33998) mbedtls: ssl_msg.c:2102 => flush output
I (33998) mbedtls: ssl_msg.c:2122 message length: 4125, out_left: 4125
I (34002) mbedtls: ssl_msg.c:2127 ssl->f_send() returned 4125 (-0xffffefe3)
I (34008) mbedtls: ssl_msg.c:2155 <= flush output
I (34013) mbedtls: ssl_msg.c:2870 <= write record
I (34019) mbedtls: ssl_msg.c:5848 <= write
I (34024) mbedtls: ssl_msg.c:5820 => write
I (34029) mbedtls: ssl_msg.c:2701 => write record
I (34034) mbedtls: ssl_msg.c:632 => encrypt buf
I (34083) mbedtls: ssl_msg.c:1120 <= encrypt buf
I (34112) mbedtls: ssl_msg.c:2102 => flush output
I (34112) mbedtls: ssl_msg.c:2122 message length: 4125, out_left: 4125
I (34116) mbedtls: ssl_msg.c:2127 ssl->f_send() returned 4125 (-0xffffefe3)
I (34122) mbedtls: ssl_msg.c:2155 <= flush output
I (34127) mbedtls: ssl_msg.c:2870 <= write record
I (34133) mbedtls: ssl_msg.c:5848 <= write
I (34138) mbedtls: ssl_msg.c:5820 => write
I (34143) mbedtls: ssl_msg.c:2701 => write record
I (34148) mbedtls: ssl_msg.c:632 => encrypt buf
I (34197) mbedtls: ssl_msg.c:1120 <= encrypt buf
I (34225) mbedtls: ssl_msg.c:2102 => flush output
I (34226) mbedtls: ssl_msg.c:2122 message length: 4125, out_left: 4125
I (34229) mbedtls: ssl_msg.c:2127 ssl->f_send() returned 4125 (-0xffffefe3)
I (34235) mbedtls: ssl_msg.c:2155 <= flush output
I (34241) mbedtls: ssl_msg.c:2870 <= write record
I (34246) mbedtls: ssl_msg.c:5848 <= write
I (34251) mbedtls: ssl_msg.c:5820 => write
I (34256) mbedtls: ssl_msg.c:2701 => write record
I (34262) mbedtls: ssl_msg.c:632 => encrypt buf
I (34310) mbedtls: ssl_msg.c:1120 <= encrypt buf
I (34338) mbedtls: ssl_msg.c:2102 => flush output
I (34339) mbedtls: ssl_msg.c:2122 message length: 4125, out_left: 4125
I (34342) mbedtls: ssl_msg.c:2127 ssl->f_send() returned 4125 (-0xffffefe3)
I (34348) mbedtls: ssl_msg.c:2155 <= flush output
I (34354) mbedtls: ssl_msg.c:2870 <= write record
I (34359) mbedtls: ssl_msg.c:5848 <= write
I (34364) mbedtls: ssl_msg.c:5820 => write
I (34369) mbedtls: ssl_msg.c:2701 => write record
I (34375) mbedtls: ssl_msg.c:632 => encrypt buf
I (34424) mbedtls: ssl_msg.c:1120 <= encrypt buf
I (34452) mbedtls: ssl_msg.c:2102 => flush output
I (34452) mbedtls: ssl_msg.c:2122 message length: 4125, out_left: 4125
I (34456) mbedtls: ssl_msg.c:2127 ssl->f_send() returned 4125 (-0xffffefe3)
I (34462) mbedtls: ssl_msg.c:2155 <= flush output
I (34467) mbedtls: ssl_msg.c:2870 <= write record
I (34473) mbedtls: ssl_msg.c:5848 <= write
I (34478) mbedtls: ssl_msg.c:5820 => write
I (34483) mbedtls: ssl_msg.c:2701 => write record
I (34488) mbedtls: ssl_msg.c:632 => encrypt buf
I (34517) mbedtls: ssl_msg.c:1120 <= encrypt buf
I (34532) mbedtls: ssl_msg.c:2102 => flush output
I (34533) mbedtls: ssl_msg.c:2122 message length: 2102, out_left: 2102
I (34536) mbedtls: ssl_msg.c:2127 ssl->f_send() returned 2102 (-0xfffff7ca)
I (34542) mbedtls: ssl_msg.c:2155 <= flush output
I (34548) mbedtls: ssl_msg.c:2870 <= write record
I (34553) mbedtls: ssl_msg.c:5848 <= write
I (34625) mbedtls: ssl_msg.c:5399 => read
I (34626) mbedtls: ssl_msg.c:3941 => read record
I (34627) mbedtls: ssl_msg.c:1886 => fetch input
I (34631) mbedtls: ssl_msg.c:2043 in_left: 0, nb_want: 5
I (34637) mbedtls: ssl_msg.c:2068 in_left: 0, nb_want: 5
I (34643) mbedtls: ssl_msg.c:2069 ssl->f_recv(_timeout)() returned 5 (-0xfffffffb)
I (34652) mbedtls: ssl_msg.c:2089 <= fetch input
I (34657) mbedtls: ssl_msg.c:1886 => fetch input
I (34662) mbedtls: ssl_msg.c:2043 in_left: 5, nb_want: 994
I (34670) mbedtls: ssl_msg.c:2068 in_left: 5, nb_want: 994
I (34675) mbedtls: ssl_msg.c:2069 ssl->f_recv(_timeout)() returned 989 (-0xfffffc23)
I (34684) mbedtls: ssl_msg.c:2089 <= fetch input
I (34696) mbedtls: ssl_msg.c:1144 => decrypt buf
I (34700) mbedtls: ssl_msg.c:1741 <= decrypt buf
I (34707) mbedtls: ssl_msg.c:4015 <= read record
I (34708) mbedtls: ssl_msg.c:5693 <= read
I (34711) mbedtls: ssl_msg.c:5399 => read
I (34715) mbedtls: ssl_msg.c:5693 <= read
I (34721) HTTP_CLIENT: Body received in fetch header state, 0x3fcb4de2, 177
I (34729) mbedtls: ssl_msg.c:5399 => read
I (34733) mbedtls: ssl_msg.c:3941 => read record
I (34738) mbedtls: ssl_msg.c:1886 => fetch input
I (34744) mbedtls: ssl_msg.c:2043 in_left: 0, nb_want: 5
I (34750) mbedtls: ssl_msg.c:2068 in_left: 0, nb_want: 5
I (34756) mbedtls: ssl_msg.c:2069 ssl->f_recv(_timeout)() returned 5 (-0xfffffffb)
I (34764) mbedtls: ssl_msg.c:2089 <= fetch input
I (34770) mbedtls: ssl_msg.c:1886 => fetch input
I (34775) mbedtls: ssl_msg.c:2043 in_left: 5, nb_want: 34
I (34782) mbedtls: ssl_msg.c:2068 in_left: 5, nb_want: 34
I (34788) mbedtls: ssl_msg.c:2069 ssl->f_recv(_timeout)() returned 29 (-0xffffffe3)
I (34796) mbedtls: ssl_msg.c:2089 <= fetch input
I (34802) mbedtls: ssl_msg.c:1144 => decrypt buf
I (34808) mbedtls: ssl_msg.c:1741 <= decrypt buf
I (34813) mbedtls: ssl_msg.c:4015 <= read record
I (34818) mbedtls: ssl_msg.c:5693 <= read
I (34823) ms_http_client: end_time 2:33574
I (34828) ms_http_client: average_time 2:2111:2999
I (34833) ms_http_client: HTTP POST Status = 200, content_length = -1
