Fixed CCRs: SPB 17.2 HF015 03-16-2017 ================================================================= CCRID Product ProductLevel2 title ================================================================= 1653366 ALLEGRO_EDITOR INTERFACES Unable to attach step model to symbol 1671760 ALLEGRO_EDITOR INTERFACES Step package mapping window unable to display step model 1706879 ALLEGRO_EDITOR MANUFACT Trace gets moved to dielectric layer after using the Gloss function 1708685 ALLEGRO_EDITOR MANUFACT Incomplete ncdrill holes data in drl file 1712057 ALLEGRO_EDITOR PAD_EDITOR Changing text size and restarting padstack Editor results in incorrectly scaled forms 1709335 ALLEGRO_EDITOR SCHEM_FTB Cannot import netlist from attached design 1687329 ALLEGRO_EDITOR SHAPE Shape is not voiding uniformly when component is rotated in 30 degrees 1698539 ALLEGRO_EDITOR SHAPE A thin shape is left when dv_fixfullcontact is enabled. 1620210 ALLEGRO_EDITOR UI_GENERAL Need to run PCB Editor from both 17.2-2016 and 16.6 releases simultaneously 1687819 ALLEGRO_EDITOR UI_GENERAL Change in Region and Language settings of Windows impacts decimal character in Padstack Editor 1699326 ALLEGRO_EDITOR UI_GENERAL Padstack Editor follows the geographical area rules set in the Control Panel while PCB Editor does not 1711341 ALLEGRO_EDITOR UI_GENERAL Incorrect pad size in Padstack Editor when the German regional settings are used 1712496 ALLEGRO_EDITOR UI_GENERAL Padstack Editor shows incorrect values when using comma and 3 decimal places 1714744 ALLEGRO_EDITOR UI_GENERAL Using comma instead of dot as integer separator results in incorrect diameter value 1715714 ALLEGRO_EDITOR UI_GENERAL If the 'Decimal places' field is set to 3, values in PAD Designer change automatically 1713292 APD WIREBOND Allegro Package Designer crashes when adding wire to a die pad 1710973 ASDA PACKAGER Unable to export Allegro SDA project to PCB Layout 1698697 CONCEPT_HDL COPY_PROJECT Copy project corrupts the .dcf file 1705401 CONCEPT_HDL CORE Alignment issues while pasting signal names in 16.6 Hotfix 084 1707116 CONCEPT_HDL CORE SIG_NAME is placed on non-grid position 1710486 CONCEPT_HDL CORE Rename Signal places sig_name at an incorrect position for an unnamed net 1667786 CONSTRAINT_MGR XNET_DIFFPAIR Parts with NO_XNET_CONNECTION getting extracted into SigXplorer 1709508 SIG_INTEGRITY REPORTS Allegro Sigrity SI crashes when running a reflection simulation 1710097 SIP_LAYOUT DIE_STACK_EDI The IY option of the 'move and stretch wire' command moves the die to incorrect coordinates 1712964 SIP_LAYOUT SYMBOL SiP Layout crashes when using Renumber Pins in Symbol Edit application mode 链接:http://pan.baidu.com/s/1kVmHGZ9 密码:smsv |
5524 浏览 1 评论
分享资深硬件工程师用cadence仿真DDR3 SDRAM视频---- sigxplorer信号完整性仿真例子 ...
78848 浏览 323 评论
5572 浏览 1 评论
32451 浏览 2 评论
李增老师:Cadence Allegro 17.2 如何制作逼真的3D PCB模型和进行3D设计检查
15769 浏览 11 评论
GMT+8, 2024-12-29 11:36 , Processed in 0.387475 second(s), Total 64, Slave 47 queries .
