AVR技术william hill官网
13年用户 92经验值
擅长:嵌入式技术
[AVR问答]
atmega16驱动AT24C02问题?
unsigned char at24c02_sda_io(void)  //修改IO口方向
DDRD&=~(BIT(5));
PORTD|=(BIT(5));
if((PIND&0x20)==0x00){return 0;}
else{return 1;}
void at24c02_init(void)   //at24c02初始化,开始状态都为"空闲"
at24c02_sda_set;
delayus(5);
at24c02_scl_set;
delayus(5);
void at24c02_start(void)   //at2c02启动信号;SCL高电平下,SDA从高电平到低电平的跳变
at24c02_sda_set;
delayus(5);
at24c02_scl_set;
delayus(5);
at24c02_sda_clr;
delayus(5);
void at24c02_stop(void)   //at24c02停止信号;SCL高电平下,SDA从低电平到高电平的跳变
at24c02_sda_clr;
delayus(5);
at24c02_scl_set;
delayus(5);
at24c02_sda_set;
delayus(5);
void at24c02_response(void)  //at24c02应答响应信号;SCL高电平下,如果at24c02收到数据,则会SDA拉低
  unsigned int x=0;
  at24c02_scl_set;
  delayus(5);
  while((at24c02_sda_io())&&(x<1000))x++;   //等待是否有应答,如果一段时间应答不成功,则默认为应答成功
  at24c02_scl_clr;
  delayus(5);
unsigned char at24c02_read_byte(void)    //从at24c02读出数据
unsigned char x,y;
at24c02_scl_clr;
delayus(5);
at24c02_sda_set;
delayus(5);
for(x=0;x<8;x++)
  at24c02_scl_clr;
  delayus(5);
  y=(y<<1)|at24c02_sda_io();
  delayus(5);
  at24c02_scl_set;
  delayus(5);
return y;
void at24c02_write_byte(unsigned char byte)    //向at24c02写入数据
unsigned char x,y;
for(x=0;x<8;x++)
  y=byte&0x80;
  at24c02_scl_clr;
  delayus(5);
  if(y==0){at24c02_sda_clr;}
  else{at24c02_sda_set;}
  delayus(5);
  at24c02_scl_set;
  delayus(5);
  byte=byte<<1;
  delayus(5);
at24c02_scl_clr;
delayus(5);
at24c02_sda_clr;
delayus(5);
void at24c02_write_data(unsigned char add,unsigned char data)    //给at24c02指定地址写入数据
at24c02_start();
at24c02_write_byte(0xA0);   //0xA0:写数据,0xA1:读数据;
at24c02_response();
at24c02_write_byte(add);
at24c02_response();
at24c02_write_byte(data);
at24c02_response();
at24c02_stop();
delayms(10);
unsigned char at24c02_read_data(unsigned char add)    //从A24C02指定地址中读出数据
{//0xA0:写数据,0xA1:读数据;
unsigned char data;
at24c02_start();
at24c02_response();
at24c02_response();
at24c02_start();
at24c02_write_byte(0xA1);
at24c02_response();
data=at24c02_read_byte();
at24c02_stop();
delayms(10);
return data;
为什么连续写入两次数据,才能存入数据,并且正确的读出数据?如果写入一次数据的话,读出的数据还是写入之前的数据(等于数据没有存进去)??
已退回2积分
