大家好,我的工作是开发一个电梯控制器,不使用任何通信总线之间的电梯机舱,霍尔和控制器面板。取而代之的是所有的呼叫按钮和指示LED以及所有楼层的簧片开关直接连接(或通过继电器等)连接在GPIO引脚上。因此,在MCU上需要大量的PIN计数。例如,对于一个12层电梯,我估计大约90 GPIO引脚。我在想,有可能做一个可级联控制器。例如,如果我可以在MCU上调整4个楼层,然后让它与下一个(和以前)MCU的通信,每个MCU都能处理4层。这样,我可以使用40针MCU在控制箱多达所需的。它们都在UART端口上互相通信,它们可以按需要级联。如果这是可行的。你能给出一个关于固件的ALGO级设计吗?非常感谢你的帮助。
以上来自于百度翻译 以下为原文 Hello everyone I am working to develop an Elevator controller that do not use any communication bus between the Elevator Cabin, Hall and Controller panel. Instead all call buttons and indication LEDs etc and reed switches from all floors are directly (or through relays etc) are connected on the GPIO pins. So a high number of pin counts is needed on the MCU. For example for a 12 floor elevator I estimated approx. 90 GPIO pins. I was thinking that would it be possible to make a cascadable controller.. so for example if i could adjust 4 floors on a MCU and then make it communicate with next (and previous) MCU's each capable of handling 4 floors.. in this way i could use 40 pins MCUs in the Control box as many as needed.. all of them communicating with each other on UART port and they can be cascaded as many as required. If this is something doable.. can you give an algo level design about the firmware? Your help is highly appreciated. |
而不是使用巨大的MCU,为什么不只是使用一个简单的小(有一个SPI外设),菊花链平行串行移位寄存器的所有输入?7HC165芯片是这样做的伟大。
以上来自于百度翻译 以下为原文 Rather than using huge MCUs, why not just use a small simple one (that has an SPI peripheral), and daisy chain parallel to serial shift registers for all the inputs? 74HC165 chips are great for doing this. |
5292 浏览 9 评论
2059 浏览 8 评论
1969 浏览 10 评论
3234 浏览 3 评论
2277 浏览 5 评论
824浏览 1评论
710浏览 1评论
654浏览 1评论
710浏览 0评论
609浏览 0评论
GMT+8, 2025-1-15 11:38 , Processed in 1.135336 second(s), Total 74, Slave 58 queries .
