英伟达
何禄蔓
7年用户 156经验值
更新NVIDIA ESXi主机驱动程序, 我有几个关于这个的问题
我有3台主机当前正在运行NVIDIA-VMware_ESXi_6.5_Host_Driver 384.73-1OEM.650.0.0.459867。
希望更新到最新的384.111。
我之前从未更新过驱动程序,因此有几个问题
1)有3个主机,每个主机有1个GPU。
如果我只在一台主机上更新了驱动程序,那么一切还能运行吗?
我不打算这个,但只是好奇。
2)这些主机上的VM当前正在运行Windows NVIDIA Graphics Driver 385.41。
当我下载适用于vSphere 6.5的GRID包时,它包含一个新版本(386.09)。
更新主机后,385.41驱动程序版本是否可以工作,还是需要更新?
3)当我打开NVIDIA软件许可中心的“产品信息”选项卡时,“当前版本”选项卡中有两个版本。
版本4.6和版本5.2。
这对我来说有点困惑。
我打算在v5.2链接中使用驱动程序,但好奇为什么版本4.6在那里?
以上来自于谷歌翻译
以下为原文
I have 3 hosts currently running NVIDIA-VMware_ESXi_6.5_Host_Driver 384.73-1OEM.650.0.0.459867.  Looking to update to most current which is 384.111.  I've never updated the driver before so have a few questions
1) There are 3 hosts with 1 GPU each.  If I only updated the driver on one host would everything still work?  I don't plan on this but just curious.
2) The VM's on these hosts are currently running Windows NVIDIA Graphics Driver 385.41.  When I downloaded the GRID for vSphere 6.5 package it included a new version (386.09).  Will the 385.41 driver version work after I update the hosts or will that also need to be updated?
3) When I open up the Product Information tab of my NVIDIA Software Licensing Center there are two versions in the Current Releases tab.  Version 4.6 and version 5.2.  This is kind of confusing for me.  I plan on using the drivers in the v5.2 link but curious why the version 4.6 is there?
回帖(1)
李如昊
2018-9-7 16:59:46
嗨,
首先,有两个不同的“主要”分支:4.x和5.x.
您已经在使用5.x分支,因此您应该更新到5.2。
1)是的,它应该。
但我会先开始更新Windows驱动程序,然后再更新主驱动程序。
请注意,不支持运行“不匹配”主机/来宾驱动程序版本,并且仅适用于同一主要分支。
因此,如果要更新到将来的6.x版本,则需要同时更新guest / host。
问候
西蒙
以上来自于谷歌翻译
以下为原文
Hi,
First of all there are two different "major" branches: 4.x and 5.x. You are already using 5.x branch and therefore you should update to 5.2.
For 1) Yes it should. But I would start to update the Windows driver first and afterwards the host driver.
Be aware that running "non matching" host/guest driver versions is not supported and works only for the same major branch. So if you want to update to a future 6.x version you would need to update guest/host at the same time.
Regards
Simon
