`* VOFFSET 200 V max.
* IO+/- 130 mA/270 mA * VOUT 10 V - 20 V * ton/off (typ.) 220 ns/200 ns * Delay Matching (typ.) NONE * PD=0.625W 封装形式:SOP-8 适用产品: *正弦波逆变器 *变频水泵控制器 *无刷电机驱动器 *高压Class-D类功放 深力科电子专业代理sillumin高品质的驱动IC 电机与驱动IC DC-DC 电源管理IC: SLM6140 SLM6160 SLM6240 SLM6260 (运用于蓝牙音箱,媲美PAM2421/2422/2423 更高音频品质,更大功率,更高转换效率,更长的锂电待机时间) Motor Driver电机驱动IC: High and low side Driver : SLM2001S(IR2001S) SLM2005S(IR2005S) SLM2101S (IR2101S) SLM2106S(IR2106S) SLM2304S (IR2304S) Half-Bride Driver: SLM2003S (IR2003S) SLM2004S(IR2004S) SLM2103S(IR2103S) SLM2104S (IR2104S) SLM2108S (IR2108S) SLM2110S (IR2110S) SLM2184S (IR2184S) SLM2316S (IR2316S) SLM7888 Stepper Motor Driver: SLM1909 SLM8549 SLM8548 (HV8548) 均可完美代替PIN对PIN代替LV8548MC-AH (以上HVIC GATE Driver 驱动芯片可以PIN对PIN完全代替IR系列驱动芯片) LED Driver SLM501A SLM201A SLM401A SLM510A SLM211A SLM411A (以上恒流源线性驱动芯片适用于商业LED照明系统,部分型号支持PWM深度调光) ` |
3058 浏览 0 评论
2092 浏览 1 评论
4610 浏览 12 评论
GMT+8, 2024-12-27 14:39 , Processed in 0.709552 second(s), Total 47, Slave 35 queries .
