电子发烧友william hill官网
大家好,我想用ICD3使用PIC24FJ64 GA202。它在调试模式下工作得很好,但是当我尝试在发布模式下编程PIC时,它不起作用。如果我试图用IPE擦除内存,似乎操作成功了,但是如果我做了一个空白的检查,我得到了这个错误信息。空白检查…配置内存地址:ABFC预期值:B7FF收到的值:BFFBLATE检查完成,设备不是BLANK。2018~0629 16:27:15+ 0200 -空白检查失败空白检查完成,设备不是空白。2018~0629 16:27:15+ 0200 -空白检查失败。“我试图改变PIC得到相同的错误。现在我叫了其他的PIC来检查,有什么建议吗?谢谢大家的回答,祝您愉快!
以上来自于百度翻译 以下为原文 Hi all, I'm trying to use the PIC24FJ64GA202 with the ICD3. It works well in debug mode but when I attempt to program the PIC in release mode it doesn't work. If I try to erase the memory with the IPE, it seems that the operation is successfully got but if I do a Blank Check I got this error message. Blank Checking... Blank check complete, device is not blank. 2018-06-29 16:27:15 +0200 - Blank check failed" I tried to change the PIC getting the same error. At the moment I ordered other PIC to check them. Any suggestion about this? Thank to all for you answers. Have a nice day |
3个回答
您好,请您展示一下您的威廉希尔官方网站
图和您的威廉希尔官方网站
板的照片好吗?在MCLR推荐ICSP连接上有10K到50K的上拉电阻:http://WW1.Microchip .com……EVICEDOC/5002011B.PDFRGARDS
以上来自于百度翻译 以下为原文 Hi, Can you please show your schematics and a picture of your board ? Do you have a 10K to 50K pull-up resistor on MCLR Recommended ICSP connection : http://ww1.microchip.com/...eviceDoc/50002011B.pdf Regards |
调试器执行程序为您运行运行代码时不会发生的一些事情。如果我记得正确的话,其中一件事就是把你的模拟引脚设置为数字。你必须在发布模式下自己做这件事。/ Ruben
以上来自于百度翻译 以下为原文 The debugger executive does some things for you that won't happen when running release code. If I remember correctly, one of those things is setting your analog pins to digital. You have to do that by yourself in release mode. /Ruben |
你好,这里附了MCLR的连接
以上来自于百度翻译 以下为原文 Hi, here attached the connection of MCLR Attached Image(s) |
5248 浏览 9 评论
2037 浏览 8 评论
1957 浏览 10 评论
3218 浏览 3 评论
2265 浏览 5 评论
788浏览 1评论
679浏览 1评论
608浏览 1评论
685浏览 0评论
582浏览 0评论
GMT+8, 2024-12-28 07:57 , Processed in 1.399267 second(s), Total 80, Slave 64 queries .
