Dear,all:
ST公司用于振动测量加速度传感器?要求如下: 频率响应超过1万 范围:0-40克 Power:低功耗 如果ST公司没有这些传感器,用于水泵,风机和其他工业现场,您能介绍其他公司的传感器吗? 以上来自于谷歌翻译 以下为原文 Dear,all: ST companies have used for vibration measuring acceleration sensor? Requirements are as follows: Frequency response: more than 1kh Range: 0-40 g Power:Low power consumption Used in water pump, fan and other industrial sites if ST companies have not these sensor,Can you introduce other company sensor? |
3个回答
你可以考虑一下
http://www.st.com/content/st_com/en/products/mems-and-sensors/accelerometers/h3lis331dl.html 范围是100/200 / 400g,但最大输出数据速率仅为1kHz。您确定需要测量高达40g的振动吗?如果16克足够你也可以考虑 http://www.st.com/content/st_com/en/products/mems-and-sensors/accelerometers/iis2dh.html 能够提供输出数据速率高达5376 Hz的数据。 以上来自于谷歌翻译 以下为原文 You can consider http://www.st.com/content/st_com/en/products/mems-and-sensors/accelerometers/h3lis331dl.html the range is 100/200/400g, but the maximum output data rate is only 1kHz.Are you sure you need to measure vibration up to 40g? If 16g would be enough you can also consider http://www.st.com/content/st_com/en/products/mems-and-sensors/accelerometers/iis2dh.html which is capable to provide data with output data rate up to 5376 Hz. |
谢谢你的回复!
IIS2DH的ADC是12位,我认为 http://www.baidu.com/link?url=v2jdow-y-YTs0lx5nEcKCRbQqaxRDiYl2wpTrC5nmp9yz4UsOkpjqqDStHEufS66GNFrqIV-eg6iCUQmqx4otIoZ9r17zsE8WK9qa85nUdG&wd=&eqid=ed2a45eb00007641000000065a2f4e47 http://www.baidu.com/link?url=v2jdow-y-YTs0lx5nEcKCRbQqaxRDiYl2wpTrC5nmp9yz4UsOkpjqqDStHEufS66GNFrqIV-eg6iCUQmqx4otIoZ9r17zsE8WK9qa85nUdG&wd=&eqid=ed2a45eb00007641000000065a2f4e47 以上来自于谷歌翻译 以下为原文 Thanks your response! The IIS2DH' ADC is 12bit,i think the http://www.baidu.com/link?url=v2jdow-y-YTs0lx5nEcKCRbQqaxRDiYl2wpTrC5nmp9yz4UsOkpjqqDStHEufS66GNFrqIV-eg6iCUQmqx4otIoZ9r17zsE8WK9qa85nUdG&wd=&eqid=ed2a45eb00007641000000065a2f4e47 http://www.baidu.com/link?url=v2jdow-y-YTs0lx5nEcKCRbQqaxRDiYl2wpTrC5nmp9yz4UsOkpjqqDStHEufS66GNFrqIV-eg6iCUQmqx4otIoZ9r17zsE8WK9qa85nUdG&wd=&eqid=ed2a45eb00007641000000065a2f4e47 |
您可以查看ST加速度计的概述。
http://www.st.com/content/st_com/en/products/mems-and-sensors/accelerometers.html?querycriteria=productId=SC444 以上来自于谷歌翻译 以下为原文 You can check this overview of ST accelerometers. http://www.st.com/content/st_com/en/products/mems-and-sensors/accelerometers.html?querycriteria=productId=SC444 |
2775 浏览 1 评论
3251 浏览 1 评论
1822 浏览 1 评论
3666 浏览 6 评论
6060 浏览 21 评论
1347浏览 4评论
212浏览 3评论
对H747I-DISCO写程序时将CN2的st-link复用为usart1,再次烧录时无法检测到stlink怎么解决?
367浏览 2评论
STM32G474RE芯片只是串口发个数据就发烫严重是怎么回事?
463浏览 2评论
STM32处理增量式编码器Z信号如何判断中断是正转的还是反向转的?
291浏览 2评论
GMT+8, 2025-1-8 06:18 , Processed in 1.108492 second(s), Total 80, Slave 64 queries .
