电子发烧友william hill官网
喜
我有几个问题。 1. Acc的顺序抗混叠滤波器是什么? 2.陀螺的顺序抗混叠滤波器是什么? 3.如果截止频率高于nyquist频率,DLPF1滤波器如何帮助我? 谢谢, 阿米尔 #lsm6ds3#lsm6ds3 以上来自于谷歌翻译 以下为原文 hi, I've got a few questions. 1. what is the order anti-aliasing filter of the Acc? 2. what is the order anti-aliasing filter of the Gyro? 3. how does the DLPF1 filter help me if the cut-off freq is higher then nyquist freq? thank you, amir #lsm6ds3 #lsm6ds3 |
3个回答
大家好,
我对LSM9DS1有类似的问题: 1.加速度ODR选择下降到10 Hz,但带宽选择(可能是抗混叠滤波器)限制为50Hz。因此,当在10Hz或50Hz下以50Hz的带宽选择进行采样时,预期会出现严重的混叠。有没有办法避免这种情况? 2.没有正确记录加速度数字滤波器操作。 “高分辨率”指的是什么?如何选择LPF或HPF? 以上来自于谷歌翻译 以下为原文 Hi all, I have similar questions regarding the LSM9DS1: 1. The Acceleration ODR choices go down to 10 Hz, however the bandwidth selection, presumable an anti-aliasing filter, is limited to 50Hz. Thus, when sampling at 10Hz or 50Hz with a bandwidth selection of 50Hz severe aliasing is to be expected. Is there a way to avoid this? 2. The accelerometed digital filter operation is not documented properly. What dow ''high resolution'' refer to? How is LPF or HPF selected? |
嗨阿米尔,
请参阅可从ST网页下载的AN4650应用说明的第2.6章和第2.7章: http://www.st.com/resource/en/application_note/dm00157511.pdf 感谢你并致以真诚的问候, 切赫 以上来自于谷歌翻译 以下为原文 Hi Amir, please refer to the Chapters 2.6 and 2.7 of the AN4650 Application Note downloadable from ST web pages: http://www.st.com/resource/en/application_note/dm00157511.pdf Thank you and best regards, Petr |
我没有看到AN4650中的那些章节,或者任何回答问题的章节:抗锯齿滤镜的顺序是什么。我还有一个问题:陀螺抗锯齿滤波器的截止频率和阶数是多少?
担 以上来自于谷歌翻译 以下为原文 I don't see those chapters in AN4650, or anything that answers the questions: what is the order of the antialias filters. I have another question: what is the cutoff frequency and order of the gyro antialias filter? Dan |
2741 浏览 1 评论
3244 浏览 1 评论
1813 浏览 1 评论
3653 浏览 6 评论
6044 浏览 21 评论
1342浏览 4评论
203浏览 3评论
对H747I-DISCO写程序时将CN2的st-link复用为usart1,再次烧录时无法检测到stlink怎么解决?
356浏览 2评论
STM32G474RE芯片只是串口发个数据就发烫严重是怎么回事?
446浏览 2评论
STM32处理增量式编码器Z信号如何判断中断是正转的还是反向转的?
275浏览 2评论
GMT+8, 2024-12-26 22:46 , Processed in 1.252388 second(s), Total 82, Slave 66 queries .
