对ST加速度计来说,我可以看到它们被分为三个“家族” - 纳米,微微和毫微微。这三个家庭之间的差异是否有简短的解释?链接到一个页面解释,这将是困难,谢谢。
rday 以上来自于谷歌翻译 以下为原文 Totally new to ST accelerometers, I can see that they're grouped into what look like three 'families' -- nano, pico and femto. Is there a short explanation of the differences between those three families? A link to a page explaining that would be just ducky, thanks. rday |
我认为,这些都是更多的营销术语。
我宁愿使用以下矩阵代替。 也可以找到产品选择器 http://www.st.com/en/mems-and-sensors/accelerometers.html?querycriteria=productId=SC444 。 以上来自于谷歌翻译 以下为原文 I think, these are more marketing terms. I would rather use following matrix instead. Product selector can be find also http://www.st.com/en/mems-and-sensors/accelerometers.html?querycriteria=productId=SC444 . |
如果它们只是营销术语,那么产品摘要表似乎有点混淆似乎强调分类如此突出。如果我看一下LIS2DW12的页面,
http://www.st.com/content/st_com/en/products/mems-and-sensors/accelerometers/lis2dw12.html ,我在前几行告诉我这个项目是'femto'家族的成员。但是如果没有对这意味着什么的定义,那么告诉我信息是无用的甚至是混乱的,因为我读到的第一件事就是“'femto'是什么意思?我应该已经明白了吗?有没有解释它的词汇表? 'femto'比'pico'更好吗?'除非有一页解释了这些家庭之间的差异,否则提及它绝对没有营销价值。 以上来自于谷歌翻译 以下为原文 If they're just marketing terms, then it's a bit confusing for the product summary sheet to seem to emphasize that categorization so prominently. If I look at, say, the page for the LIS2DW12, http://www.st.com/content/st_com/en/products/mems-and-sensors/accelerometers/lis2dw12.html , I am told in the first few lines that this item is a member of the 'femto' family. But without a definition of what that means, then telling me that information is useless and even confusing, since the first thing I thought of when I read that is, 'What does 'femto' mean? Am I supposed to already understand that? Is there a glossary that explains it? Is 'femto' better than 'pico'?'Unless there's a page that explains the difference between those families, there's absolutely no marketing value in mentioning it. |
2747 浏览 1 评论
3244 浏览 1 评论
1813 浏览 1 评论
3655 浏览 6 评论
6045 浏览 21 评论
1342浏览 4评论
204浏览 3评论
对H747I-DISCO写程序时将CN2的st-link复用为usart1,再次烧录时无法检测到stlink怎么解决?
359浏览 2评论
STM32G474RE芯片只是串口发个数据就发烫严重是怎么回事?
451浏览 2评论
STM32处理增量式编码器Z信号如何判断中断是正转的还是反向转的?
277浏览 2评论
GMT+8, 2024-12-30 00:57 , Processed in 2.039878 second(s), Total 48, Slave 42 queries .
