电子发烧友william hill官网
我设置了一个使用NVIDIA GRID SDK编写的应用程序。
它在运行Windows Server 2012 R2的Amazon EC2 GPU实例上使用NvFBC API记录所有内容。 只要远程桌面或TeamViewer连接处于活动状态,一切正常。 只要关闭远程桌面和TeamViewer连接,就不会再将任何帧写入.h264文件。 一旦建立新连接,它就会继续。 我假设当连接没有使用显示器时,NVIDIA K520会停止渲染帧。 即使没有活动连接,如何确保帧始终呈现? 以上来自于谷歌翻译 以下为原文 I set up an application that I wrote using the NVIDIA GRID SDK. It records everything with the NvFBC API on an Amazon EC2 GPU instance running Windows Server 2012 R2. Everything works well as long as a Remote Desktop or TeamViewer connection is active. As soon as I close the Remote Desktop and TeamViewer connection no more frames are written into the .h264 file. It continues as soon as a new connection is established. I assume that the NVIDIA K520 stops rendering frames when no display is used by a connection. How can I make sure that frames are constantly being rendered even without an active connection? |
嗨,克里斯,你有没有解决这个问题?
我遇到了同样的情况 以上来自于谷歌翻译 以下为原文 Hi Chris, did u ever solve this? I'm running into the same situation |
试试AEROADMIN,我用了三年多。
用于远程控制计算机的快速且最重要的安全程序。 优点,高速,可靠的安全系统。 以上来自于谷歌翻译 以下为原文 Try AEROADMIN, I use more than three years. Fast, and most importantly safe program for remote control of computers. Advantages, high speed, reliable security system. |
使用Vsphere 6.5在Compute模式下使用2个M60卡遇到VM问题
3131 浏览 5 评论
是否有可能获得XenServer 7.1的GRID K2驱动程序?
3544 浏览 4 评论
GMT+8, 2024-12-27 23:09 , Processed in 0.627928 second(s), Total 76, Slave 60 queries .
