我会尽量不让这个长篇大论。
昨天我在我们的一台支持GRID(m10 / m60)的服务器上重新安装了esxi 6.0(dell r730自定义版本),以了解它在新的vsphere 6.5服务器设备上的表现。
我发现在重新安装软件,修补服务器并尝试在其上启动m10或m60启用的vm之后,vm将移动到群集中的其他网格服务器之一以启动。
我的第一个想法是检查图形,发现“全新安装”服务器上的图形的活动类型设置为基本,并且已共享配置的类型。
在群集中的2个正常运行的服务器上,活动类型已共享,并且已配置类型为空。
我还发现xorg服务在停止之前不会保持启动超过几秒钟。
打开桌面
电源时没有错误(我猜这是因为vm将自己移动到集群中的另一台服务器)。
我需要与图形交互以尝试更改活动类型并希望启动xorg服务,因此我将主机升级到esxi 6.5。
这允许我与图形交互并将它们更改为共享/共享直接,但不是活动类型仍然是基本的。
此外,xorg服务将不会保持打开并在我刷新屏幕后立即停止。
当电源打开时,vms仍然会从服务器上跳下来,就像瘟疫一样。
我已经比较了所有其他设置,它匹配起来。
最大的问题是xorg不会继续运行。
如果我从正常运行的服务器运行nvidia-smi,我得到nvidia-smi:找不到。
但我从其他服务器获取信息。
我不确定接下来要看什么,因为没有出现与图形相关的错误,但我觉得某处有一个复选框或者我缺少的设置。
任何帮助将非常感谢。
以上来自于谷歌翻译
以下为原文
I'll try not to make this long winded. On yesterday I reinstalled esxi 6.0 (dell r730 customized ver) on one of our GRID (m10/m60) enabled servers to see how it behaved with our new vsphere 6.5 server appliance. I found that after reinstalling the software, patching the server, and attemp
ting to start a m10 or m60 enabled vm on it, the vm would move to one of the other grid servers in the cluster to power on. My first thought was to check the graphics and found that the active type for the graphics on the "fresh install" server was set to basic and the configured type was shared. On the 2 functioning servers in the cluster, the active type was shared and blank for the configured type. I also found that the xorg service would not remain started for more than a couple of seconds before stopping. There is no error when powering on a desktop (my guess was that this was because the vm moved itself to another server in the cluster).
I needed to interact with the graphics in an attempt to change the active type and hopefully get the xorg service to start, so I upgraded the host to esxi 6.5. That allowed me to interact with the graphics and change them to shared/ shared direct, but not for the active type is still basic. Also, the xorg service will not stay on and stops itself as soon as I refresh the screen.
The vms still jump off the server when powered on like it's the plague. I have compared every other setting and it matches up. The biggest propblem is that the xorg won't stay running. If I run nvidia-smi from the functioning servers, I get nvidia-smi: not found. But I get information from the other servers. I'm not really sure what to look at next as there are no graphic related errors appearing, but I feel like there is a checkbox somewhere or a setting that I am missing. Any help would greatly appreciated.
