我想用Android应用程序接口B2B-WFWT-01XBee来打开和关闭设备,我想用PIC16F87A作为控制器
以上来自于百度翻译 以下为原文 I want to interface XB2B-WFWT-001 Xbee with android app to switch on and off device , i want to use pic16f877a as controller |
3个回答
你已经陈述了你想做的事情,但实际上你并没有问过一个问题,或者说你自己能做什么,以及你需要什么帮助。请注意,PIC16F87A是一个古老的装置。有更便宜,更好的PIC16F设备可用。
以上来自于百度翻译 以下为原文 You have stated what you want to do, but you have not actually asked a question at all, or stated what you can do yourself, and what you need help with. Be aware, the PIC16F877A is an ancient device now. There are much cheaper, better PIC16F devices available. |
这是我的学院项目,我只想使用这个控制器,请帮助我编写如何为XBE-S6B设置TCP-IP的代码
以上来自于百度翻译 以下为原文 This is my college project , I want to use this controller only, Please help me with code how to set TCP-IP for XBEE- S6B |
你还没有透露你自己的能力。没有人会为你做整个项目,除非他们获得学位。你知道如何编程PIC吗?你能让LED一秒钟精确闪烁一次吗?目前还不清楚PIC16F87A在你的项目中的位置。你是否打算把XBE模块的串行命令发送到PIC,告诉PIC关闭或打开?如果是,那么PIC没有参与TCP/IP。如果这是你需要帮助的地方,你应该询问XBee支持william hill官网
以上来自于百度翻译 以下为原文 You still have not revealed what capabilities you have yourself. No-one here is going to do the whole project for you, unless they get the degree instead. Do you know how to program a PIC? Can you make an LED flash precisely once a second? It's unclear where the PIC16F877A fits into your project. Are you intending to just send serial commands from the XBEE module to the PIC, telling the PIC to turn something off or on? If yes, then the PIC has no involvement with TCP/IP. If that is where you need help, you should ask on an XBEE support forum. |
5295 浏览 9 评论
2059 浏览 8 评论
1969 浏览 10 评论
3234 浏览 3 评论
2277 浏览 5 评论
824浏览 1评论
710浏览 1评论
654浏览 1评论
711浏览 0评论
609浏览 0评论
GMT+8, 2025-1-16 04:33 , Processed in 1.330959 second(s), Total 79, Slave 63 queries .
