是德科技
孙燕冉
7年用户 328经验值
PNA-X FW 1.10.47.03 SMC测量类X轴问题
嗨,我在这里使用PNA-X系统上的A.10.47.03固件。
我无法升级到a.10.49.02,因为有一个说明它无法与Opt 90一起正常工作。我遇到的问题是,现在创建一个新的smc时行为似乎有所不同
具有此固件版本的测量通道。
之前,默认的x轴使用混频器的输出频率(用于SC21测量)。
但现在,它似乎已经改为默认输入频率范围!
它似乎也影响了VMC测量类测量。
但是,NFX和IMDX的行为与以前的固件相同。
(即默认X轴是调音台的输出频率。)如果您的团队可以修复SMC&
VMC默认的x轴行为回到先前的固件行为,这将非常感激。
谢谢,rok
以上来自于谷歌翻译
     以下为原文
  Hi,
I am using A.10.47.03 firmware on the PNA-X systems here. I can't upgrade to the a.10.49.02, since there's a note that it won't work properly with Opt 90.
The issue I'm encountering is that there seems to be a difference in behavior now when creating a new smc measurement channel with this firmware version. Before, the default x-axis was using the output frequency of the mixer (for a SC21 measurement). But now, it seems that it's changed to default to the input frequency range! It seems it also affected the VMC measurement class measurements as well. However, both the NFX and IMDX are behaving the same way as the previous firmwares. (i.e. default X-axis is the output frequency of the mixer.)
If your team can fix the SMC & VMC default x-axis behavior back to the prior firmware behavior, that would be greatly appreciated.
Thanks,
rok
回帖(4)
孔德羲
2018-9-27 15:55:58
A.10.49.03已发布。
我们认为,并希望它完全没有错误!
以上来自于谷歌翻译
     以下为原文
  A.10.49.03 has been posted. We think, and hope, it completely bug free!
孙燕冉
2018-9-27 16:12:38
引用: 脑洞大赛9 发表于 2018-9-27 18:10
A.10.49.03已发布。
我们认为,并希望它完全没有错误!
嗨乔尔博士,谢谢你的回复。
我刚刚安装了A.10.49.03最新固件,但在创建新的SMC测量通道时,使用混频器输入频率侧的X轴问题仍然存在。
韩国
以上来自于谷歌翻译
     以下为原文
  Hi Dr Joel,
Thanks for the reply. I just installed the A.10.49.03 latest firmware, but the problem with the X-axis using the input frequency side of the mixer as the default still remains when creating a new SMC measurement channel.
rok
仲娜娜
2018-9-27 16:30:32
谢谢你的缺陷报告。
我们已经找到了问题,我们已经修复了它。
较新版本的固件将包含此修复程序。
当有可用的beta版本时,我可以通知您
以上来自于谷歌翻译
     以下为原文
  Thank you for the defect report. We've found the issue, and we've fixed it. Newer releases of firmware will include this fix.
I can let you know when there is a beta build available
孙燕冉
2018-9-27 16:35:32
引用: 60user56 发表于 2018-9-27 18:44
谢谢你的缺陷报告。
我们已经找到了问题,我们已经修复了它。
较新版本的固件将包含此修复程序。
嗨,感谢您的更新和确认。
我将等待固件的下一个版本。
再次感谢,rok
以上来自于谷歌翻译
     以下为原文
  Hi,
Thanks for the update and acknowledgement. I'll wait for the next release of the firmware.
Thanks again,
rok
