如果您指定传输阶段,则会有S21 = sqrt(S11),因此我建议将相位响应除以2.这相当于将限制设置为+ -2。
但是输入反射错误会导致更大的涟漪。
这是自动夹具移除的完美应用,它可以给出电缆的S参数,仅打开测量,并消除不匹配的影响。
以上来自于谷歌翻译
以下为原文
If you are specifying the transmission phase, you would have S21=sqrt(S11), so I would suggest dividing the phase response by 2. That would be equivalent to setting the limit at +-2. But input reflection errors can cause much bigger ripples. This is a perfect application for Automatic Fixture Removal, which would give the S-parameters of the cable, with an open only measurement, and remove the effects of mismatch.
但是输入反射错误会导致更大的涟漪。
以上来自于谷歌翻译
以下为原文
