即使没有硬件接口,仿真模式也可用于探索APW的特性和功能(
http://www.st.com/web/en/catalog/tools/PF253187
/ http://www.st.com/web/en/catalog/tools/FM116/SC1028/PF258331
)被安装到PC USB端口。
例如,它还可用于检索特定声音终端设备的寄存器映射和设置信息 - 无需为实际评估板供电并连接到PC而烦恼。用户在GUI控件上的事件通过“日志查看器”面板进行完全记录和公开,例如,可以重复使用文本信息来编写用户的控制软件。
以上来自于谷歌翻译
以下为原文
The simulation mode can be used to explore APW features and capabilities even if no hardware interface (
) is connceted to the PC USB port.
It could also be used to retrieved register mapping and setting information for specific Sound Terminal devices, for instance - without the hassle to have an actual evaluation board powered and connected to the PC. User's events on the GUI controls are fully logged and exposed via the ''Log Viewer'' panel and the textual information can be re-used to write user's control software, for instance.
)被安装到PC USB端口。
以上来自于谷歌翻译
以下为原文
