我的speci5 8600k
asrock z370极端3 wd blue 2tb -gpt(我要加速的驱动器) samsung 270 evo nvme m.2 -gpt(启动不支持的系统驱动器错误驱动器) CSM禁用 RST已启用 重新安装后我得到了这个错误 43569414_281050799404067_5615167022187937792_n.jpg 90.8 K. optane3.jpg 210.6 K. optane4.jpg 128.9 K. 以上来自于谷歌翻译 以下为原文 my spec i5 8600k asrock z370 extreme 3 wd blue 2tb -gpt (drive that i want to accelerate) samsung 270 evo nvme m.2 -gpt (boot drive) CSM disabled RST enabled after reinstall i got this error
您好xbreaker316,感谢您在英特尔®社区发布。从磁盘管理屏幕截图看,您的启动驱动器实际上是蓝色驱动器,而三星驱动器只是一个带有单个C:分区的辅助驱动器。启动驱动器
除了主屏幕之外还应该有其他分区,就像屏幕截图中的磁盘0一样。请确认哪个驱动器确实是启动驱动器,因为我们可能会有困惑。另一方面,请下载英特尔® 系统支持实用程序(SSU)来自以下站点并运行完整报告以收集您的系统信息? 该工具可以从以下站点下载:https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-。 请在回复中附上报告文件。还请截取以下信息的屏幕截图: 以管理员身份打开命令提示符。 运行命令diskpart。 运行命令列表磁盘。 请截取输出的截图并将其包含在您的回复中。我将等待您的回复。祝您有个美好的一天。感谢,Diego V. 以上来自于谷歌翻译 以下为原文 Hi xbreaker316, Thank you for posting in the Intel® communities. From the Disk Management screenshot, it looks like your booting drive is actually the wd blue drive while the Samsung drive is just a secondary drive with a single C: partition. The boot drive should have other partitions besides the main one, just as it appears for the Disk 0 in the screenshot. Please confirm which drive is indeed the boot drive because we may have a confusion here. On the other hand, could you please download the Intel® System Support Utility (SSU) from the following site and run the full report to collect your system information? The tool can be downloaded from this site: https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-. Please attach the report file in your response. Please also take a screenshot of the following information:
I’ll be waiting for your response. Have a nice day. Regards, Diego V. |
jerry1978 发表于 2018-10-15 14:24 我重新安装窗口,然后我遇到了新的错误 我想我在970 evo上安装了窗口,所以我重新安装但是仍然有相同的分区设置 为了您的要求 report.txt.zip 5.4 K. 以上来自于谷歌翻译 以下为原文 I reinstall window then I got new error I think I install window on 970 evo, so I reinstall but I still got same partition setting for your request
449浏览 0评论
GMT+8, 2024-11-13 10:27 , Processed in 0.590679 second(s), Total 50, Slave 44 queries .
