我们发现的唯一解决方案是使用以太网端口而不是USB端口。
但这显然是Keysight I / O库中的Keysight软件问题,因为我还使用NI LabVIEW对使用NI VISA I / O库的34972A进行编程,34972A通过USB端口完美运行。
顺便说一下,我们也没有高速扫描34972A。
我们每分钟只采集一次数据,但是如果您观察仪器,您可以看到扫描之间经常进行一些通信。
旧的34970A使用串行或GPIB没有发生这种情况。编辑:AlphaBob于2015年7月29日上午8:59
以上来自于谷歌翻译
以下为原文
The only solution we have found is to use the Ethernet port instead of the USB port.
But this is obviously a Keysight software problem in the Keysight I/O libraries as I also program the 34972A with National Instruments LabVIEW that uses NI VISA I/O libraries and the 34972A runs flawlessly through the USB port.
By the way we are not scanning the 34972A at a high rate either. We are only taking data once a minute, but if you watch the instrument you can see the some communication is constantly going on between scans. This did not happen on the old 34970A's using serial or GPIB.
Edited by: AlphaBob on Jul 29, 2015 8:59 AM
以上来自于谷歌翻译
以下为原文
