仪器可能具有错误的地址设置,或者两个或多个仪器设置为相同的地址。
Connection Expert中配置的地址必须与仪器的地址设置相匹配。
您可以从前面板检查34972A地址。
由于它正在工作,为34972A循环供电并刷新ACE应该重新建立与34972A的通信。
我将与IO Libraries专家核实并回复您。
以上来自于谷歌翻译
以下为原文
The instrument may have the wrong address setting or two or more instruments are set to the same address. The address configured in Connection Expert must match the address setting of the instrument. You can check the 34972A address from the front panel.
Since it was working, cycling power to the 34972A and refreshing ACE should reestablish communication with the 34972A. I will check with the IO Libraries expert and get back to you on this.
您可以从前面板检查34972A地址。
以上来自于谷歌翻译
以下为原文
