你的正确,你没有砖34972A砖。
使用带有GPIB的数据记录器(我认为使用USB),您可以暂停程序,关闭仪器电源然后再打开,然后继续使用“旧”连接仍在工作的程序。您无法使用LAN执行此操作 - 一次
仪器关闭,连接已完成且无法恢复。应用程序必须在仪器重新打开后获得新的LAN连接 - 旧的LAN连接不存在。
以上来自于谷歌翻译
以下为原文
Your correct, you did not brick your 34972A.
Using datalogger with GPIB (and I think with USB), you can pause a program, cycle the instrument power OFF and then back ON, and then continue the program with the “old” connection still working.
You cannot do this with LAN – once the instrument goes down, the connection is GONE and does not come back.
The application must acquire a new LAN connection after the instrument is powered back on – that old LAN connection is not there.
你的正确,你没有砖34972A砖。
以上来自于谷歌翻译
以下为原文
