STM8S MCU的中断延迟是多少?我是STM8的新手,我读过的几篇文档都没有提到它。
以上来自于谷歌翻译 以下为原文 What is the interrupt latency on STM8S MCUs? I am new to STM8 and the few docs I have read do not mention it. |
4个回答
PM0044 - STM8 CPU编程手册 - 包含答案。
第3章的图2显示中断需要9个时钟周期进行维护。 以上来自于谷歌翻译 以下为原文 PM0044 - STM8 CPU Programming Manual - contains the answer. Figure 2 of Chapter 3 shows that an interrupt takes nine clock cycles to be serviced. |
这是正确的,但由于ST FW库存在问题,人们可以看到更大的时间,更大的时间。
我使用STM8L151,EWSTM8。在进入RTC唤醒ISR时,我将一个引脚切换并连接示波器探头。我连接到CCO的另一个探测器,路由HSI。 MCU正在进入Active Halt模式一段时间然后 - 唤醒。看看这两个探测器,我看到唤醒和进入RTC ISR之间的差距是7.5us,这是中断延迟,你要问的是。如果项目是使用Cosmic或IAR构建的,但是没有ST lib,那么确实可以看到上面提到的9个循环。 以上来自于谷歌翻译 以下为原文 It's correct but one can see a different time, much larger, due to a problem with ST FW library. I work with STM8L151, EWSTM8. On entry to RTC wakeup ISR I put a pin toggling and connected oscilloscope probe. Another probe I connected to CCO, routing HSI. MCU is moving to Active Halt mode for a certain time and then - waking up. Looking at the both probes, I saw a difference of 7.5us between the wakeup and getting into RTC ISR, which is the interrupt latency, you're asking about. If the project is built with Cosmic or with IAR, but without ST lib, then, indeed, the mentioned 9 cycles are seen. |
亲爱的RobG,
你能分享你的解决方案吗?我找不到自己的。除了头文件之外,我根本不使用ST FW lib。 此致,德米特里。 以上来自于谷歌翻译 以下为原文 Dear RobG, Could you share your solution? I can't find my own. I'm not using ST FW lib at all except header files. Regards, Dmitry. |
2901 浏览 1 评论
3285 浏览 1 评论
1866 浏览 1 评论
3718 浏览 6 评论
6131 浏览 21 评论
GMT+8, 2025-3-7 11:24 , Processed in 0.904360 second(s), Total 83, Slave 67 queries .
