扫一扫,分享给好友
我需要每个指令的时钟周期(CPI)和具有4个内核的i7 7700hq芯片的每秒数百万条指令(MIPS)。
有人可以帮我吗? 以上来自于谷歌翻译 以下为原文 i need the clock cycles per instruction(CPI) and millions of instructions per second(MIPS) of a i7 7700hq chip with 4 cores. Can someone help me with it? |
4个回答
您好,shreyas @ 007.感谢您加入英特尔社区。请允许我仔细检查您的请求可用信息。
我很快就会回复你.Antony S. 以上来自于谷歌翻译 以下为原文 Hello, shreyas@007. Thank you for joining the Intel Community. Allow me to double check the information available for your request. I will be back to you soon. Antony S. |
是的,确定。 谢谢。 以上来自于谷歌翻译 以下为原文 Yes sure. Thank you. |
您好,shreyas @ 007.如需获取更多信息,请参阅以下链接:https://www.intel.com/content/www/us/en/support/articles/000005755/processors.html请注意,CTP计算 基于1993年12月21日Wassenaar谈判得出的修改后的公式,并在美国商务部出口管理条例15 CFR 774(第4类咨询说明4)中公布,并以每秒数百万理论运算量表示 (MTOPS)。对于未上市的处理器,请查看所附网站底部的注释.Antony S.Intel客户支持技术人员与英特尔公司签订的合同 以上来自于谷歌翻译 以下为原文 Hello, shreyas@007. In order to get more information, please refer to the following link: https://www.intel.com/content/www/us/en/support/articles/000005755/processors.html Please note that CTP calculations are based upon a modified formula resulting from Wassenaar negotiations on December 21, 1993, and published in the United States Department of Commerce Export Administration Regulations 15 CFR 774 (Advisory Note 4 for Category 4), and are stated in Millions of Theoretical Operations Per Second (MTOPS). For unlisted processors, please check the notes located at the bottom of the site attached. Antony S. Intel Customer Support Technician Under Contract to Intel Corporation |
jerry1978 发表于 2018-10-31 18:34 谢谢。 以上来自于谷歌翻译 以下为原文 Thank You. |
528浏览 0评论
GMT+8, 2025-1-4 16:02 , Processed in 0.994471 second(s), Total 83, Slave 67 queries .
