我的电脑说配置是16 GB ..但它会支持32 GB ??
以上来自于谷歌翻译 以下为原文 my pc says it is configuration is for 16 GB ..but will it support a 32 GB ?? |
5个回答
在任何人可以帮助您之前,您需要提供PC或主板的确切型号。
您可能还想联系PC的支持william hill官网 并从那里开始,因为他们将在您的PC /主板上提供技术文档。 文件 以上来自于谷歌翻译 以下为原文 You need to provide the exact model number of your PC or motherboard before anyone can help you. You may also want to contact the support forum of your PC and start there, as they will have the technical documentation on your PC/motherboard. Doc |
mapleasdf 发表于 2018-11-6 10:30 嘿al ..我有一个xps 8930,这是所有配置。 对于英特尔的optane记忆,但仔细观察它说配置。 对于16 GB,我有一个32GB ..thats只是想知道是否会发生任何事情..thanxxs 以上来自于谷歌翻译 以下为原文 hey al ..I have an xps 8930 that is all config. for the intel optane memory ,but looking closer it said config. for 16 GB and I have a 32GB ..thats all just want to know if anything would happen..thanxxs |
玫瑰十一朵玲玲 发表于 2018-11-6 10:41 如果它明确声明支持16gb而不是32gb,我会与戴尔核实进行验证。 戴尔可能还有一个bios更新可以帮助您。 文件 以上来自于谷歌翻译 以下为原文 If it specifically states support for 16gb, and not 32gb, I would check with Dell to verify. There may also be a bios update from Dell which could help you. Doc |
thanxxs 以上来自于谷歌翻译 以下为原文 thanxxs |
嗨rover43,感谢您在英特尔社区发帖。我试图在以下Dell *网站上找到任何参考:https://www.dell.com/en-us/shop/dell-desktop-computers/xps- Tower / spd / xps-8930-desktop,但是没有提及对支持Intel®Optane™内存32GB版本的支持,尽管有关于支持16GB版本的明确说明。最好的建议是联系戴尔 关于这个问题。 他们将能够清除你的怀疑。 在上面的网站中,有一部分用户提出问题/答案,您可能会发现这些问题很有用。如果还有其他任何我们可以帮助您,请随时提出。祝您有个美好的一天.Regards,Diego V 。 以上来自于谷歌翻译 以下为原文 Hi rover43, Thank you for posting in the Intel communities. I was trying to find any reference in the following Dell* site: https://www.dell.com/en-us/shop/dell-desktop-computers/xps-tower/spd/xps-8930-desktop, however there is no mention about the support for the Intel® Optane™ Memory 32GB version, although there is a clear note about the support for the 16GB version. The best recommendation indeed is to contact Dell about this concern. They will be able to clear out your doubt. In the site above there is a section of questions/answer by the users that you may find useful to post this concern. If there is anything else we can help you with, feel free to ask. Have a nice day. Regards, Diego V. |
533浏览 0评论
GMT+8, 2025-1-8 12:02 , Processed in 0.680713 second(s), Total 84, Slave 68 queries .
