你好,
我们正在使用H3LIS331DL来记录我们仪器的震动。 当加速度>阈值时,我们设置INT1来中断。 当中断发生时,我们读出值并存储它。 我们观察到有时候我们会读出低于阈值的加速度。 为什么会发生这种情况 普拉迪普 #authentix#h3lis331dl 以上来自于谷歌翻译 以下为原文 hello, we are using H3LIS331DL to record shock on our instrument. we have setup INT1 to interrupt when acceleration>threshold. when the interrupt occurs we read out values and store it. we have observed that sometimes we read out acceleration that is less than threshold. why is this happening Pradeep #authentix #h3lis331dl |
我想这是由中断发生的时间和从输出寄存器读取值的时间之间的延迟引起的。如果超短时间超过阈值,您可以读取已经低于阈值的后续值。您可以尝试减少传感器ODR和/或优化MCU的代码,如果发生中断,它会读取值。
以上来自于谷歌翻译 以下为原文 I suppose it is caused by a delay between the time when interrupt occurs and the time you read the value from output registers. In case of very short peek which exceed the threshold, you can read subsequent value which is already lower then the threshold. You can try to decrease the sensor ODR and/or optimize code for your MCU, which reads the value if interrupt occurs. |
米罗斯拉夫,谢谢你的回应。
ODR = 1KHz。这意味着我们在更新内部寄存器之间有1ms。 一旦中断发生,我们就会在750微秒内读出所有6个值,因此我们错过任何值的可能性非常小。 '你可以尝试减少传感器ODR' - 这将如何帮助我们读取非常短的峰值? 普拉迪普 以上来自于谷歌翻译 以下为原文 Miroslav, thanks for responding. ODR = 1KHz. this means we have 1ms between updates of internal registers. Once the interrupt occurs, we read out all 6 values within 750 micro seconds, so the chances of us missing any value is very small. 'You can try to decrease the sensor ODR' -- how will this help us read the values of a very short peak? Pradeep |
2762 浏览 1 评论
3248 浏览 1 评论
1820 浏览 1 评论
3663 浏览 6 评论
6055 浏览 21 评论
1346浏览 4评论
209浏览 3评论
对H747I-DISCO写程序时将CN2的st-link复用为usart1,再次烧录时无法检测到stlink怎么解决?
364浏览 2评论
STM32G474RE芯片只是串口发个数据就发烫严重是怎么回事?
458浏览 2评论
STM32处理增量式编码器Z信号如何判断中断是正转的还是反向转的?
281浏览 2评论
GMT+8, 2025-1-4 12:00 , Processed in 1.042148 second(s), Total 78, Slave 62 queries .
