你好,我开始使用ATMEGA128的一个新项目。我有一个老式STK500 DEV Boad,包含一个ATMEGA128的STK501子板。一些“入门”的问题:1。AVR Studio V7似乎不支持STK500。但是有STK600的支持。例如,在文件& GT;新& GT;示例项目中,STK600是列出的董事会之一。有什么建议,我需要修改,以便港口现有STK600项目到STK500?2。同时,我创建了一个新的GCC C可执行项目(文件-gt;新& gt;Project),它只包含一个空的主()函数,然后添加一些循环代码来闪存STK500上的LED。那个简单的代码工作。但是现在我想在那个工作代码上运行调试器。在AVR Studio中,“开始调试”图标是活动的,但是当我单击它时,在代码被构建之后,我在主()中的第一行上看不到黄色箭头。在AVR Studio中,在命令栏中,我看到了我的目标CPU =“ATMEGA128”,然后在它旁边,“STK500上的ISP”。因此,我的目标连接似乎很好(注意我可以手动编程我的程序到Flash OK)。在STK500上调试我缺少了什么?如果调试器先程序闪存,然后跳转到主开始并停止?谢谢,基思
以上来自于百度翻译 以下为原文 Hello, I'm starting on a new project using the ATmega128. I have an older STK500 dev board with a STK501 daughterboard containing a ATmega128. A couple of 'getting started' questions: 1. AVR Studio v7 doesn't appear to support the STK500. But there is support for the STK600. For example, in the File -> New -> Example Project the STK600 is among the listed boards. Any suggestions on what I need to modify in order to port an existing STK600 project to the STK500? 2. In the meantime, I created a new GCC C executable project (File -> New -> Project) that simply contains a empty main() function, then added some looping code to flash the LEDs on the STK500. That simple code works. But now I want to run the debugger on that working code. In AVR Studio the 'Start Debugging' icons are active but when I click on it, after the code is built, I don't see a yellow arrow at the first line in main(). In AVR Studio, in the command bar I see my target CPU = 'ATmega128' and next to it, 'ISP on STK500'. So it seems my target connection is good (note that I can manually program my program into flash OK.) What am I missing in order to debug on the STK500? Should the debugger program the flash first then jump to the start of main and halt? Thanks, Keith |
在ATMEL工具和芯片上,您将得不到太多的支持。在Atmelwilliam hill官网
或AVRFRADK中更好的搜索(和POST),这一个(POST 4和11)应该给您答案:HTTP://www. avrFrask.NET/FounM/Salver问题STK500。
以上来自于百度翻译 以下为原文 You will not (yet) get much support here for the Atmel tools and chips. Better search (and post) in Atmel Forums or avrfreaks, this one (post #4 and #11) should give you the answer http://www.avrfreaks.net/forum/solved-problem-stk500 |
Microchip在这里没有移动AVR。也许在这里:HTTPS://社区。
以上来自于百度翻译 以下为原文 Microchip did not move AVR here yet. maybe here: https://community.atmel.com/communities |
5289 浏览 9 评论
2059 浏览 8 评论
1969 浏览 10 评论
3233 浏览 3 评论
2277 浏览 5 评论
824浏览 1评论
710浏览 1评论
654浏览 1评论
710浏览 0评论
608浏览 0评论
GMT+8, 2025-1-14 01:59 , Processed in 1.213202 second(s), Total 77, Slave 61 queries .
